Footpeg and shift lever question - Triumph Forum: Triumph Rat Motorcycle Forums
Sponsored by: National Powersports Distributors
post #1 of 8 (permalink) Old 11-08-2012, 05:30 PM Thread Starter
Main Motorcycle: Moro Guzzi Griso 1100
Other Motorcycle: Cannondale CAAD9 Team
Sat on a Thruxton for the first time today.
Everything I read was saying that this isn't going to work for me at 6'3", but it felt perfect!! Almost.
The almost was my damn size 13 foot in my Sidi Canyon boot was having an impossible time getting under the lever for upshifts.
So that leads me to my questions. Can you loosen the lever's center allen bolt and rotate the lever up a few degrees? Or is there a different lever that would work better for the large feet'd people out there?
As a comparison, I sat on a Speed Triple (not interested in the bike, but it was there) and the foot controls were perfect.
Birch is offline
post #2 of 8 (permalink) Old 11-08-2012, 07:04 PM
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Location: Toowoomba Queensland Australia (soggy bottom)
Other Motorcycle: '68 Benelli 350'
Extra Motorcycle: '60 Morini Tresette 175
The short answer.........Yes. you can rotate the lever
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
ozbon is online now
post #3 of 8 (permalink) Old 11-08-2012, 07:23 PM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Isn't the lever remote fron the changer shaft and can't the linkage length be altered to rotate the lever? I don't think the centre bolt does anything for you.
GDCobra is offline
post #4 of 8 (permalink) Old 11-08-2012, 07:26 PM
richm's Avatar
Hey Birch - There is a fair bit of adjustment in the linkage and you should be able to get it set up right. I'm 6'2" and my riding boots are my old combat boots and I have no problems.
Do your self a big favour and get the Thruxton!
richm is offline
post #5 of 8 (permalink) Old 11-09-2012, 06:51 AM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
Distance between peg centre and gear lever peg is 5 1/2 ins and cant be adjusted...but the angle can by adjusting the linkage....6' 6" and 37" inside leg size 12 boot Thruxton fits me fine.....
T.U.D.
tonupdave is offline
post #6 of 8 (permalink) Old 11-09-2012, 09:24 AM Thread Starter
TUD... I was hoping so. By rotating the lever up a few degrees, I'd be good.
End of the riding season here in Chicago, but will spend the winter looking and saving up!
If I could demo a Thrux and a TBS back to back, I might be able to make up my mind!
Birch is offline
post #7 of 8 (permalink) Old 11-10-2012, 01:37 AM Thread Starter
I guess a similar question (or one for a different thread).... Does adding Thruxton rear sets to a Bonneville give the same leg position?
Birch is offline
post #8 of 8 (permalink) Old 11-11-2012, 10:58 AM
Yes its the same frame only bars, wheels, and suspenion different to make steering geometery steeper
T.U.D.
Shift Lever Ratchet Question... biker7 Twins Technical Talk 44 08-14-2009 03:01 PM
Shift lever question Jakemuay Twins Technical Talk 4 03-05-2008 05:49 AM
2001 Sprint Shift lever question Hokie Sprint Forum 5 07-29-2006 10:14 PM
Question about lowering the gear shift lever. Triumph SuperSports 3 07-19-2004 03:50 AM
