The main reason I traded-in my 2000 W650 was the crappy gas we have around here draws moisture and the pilot jets would get plugged. The carbs are somewhat of a nightmare to remove, so when I did - I replaced the float bowl phillips-head screws w/ allen heads. That way, if you need to, you can remove the float bowls w/ the carbs attached. If the bike sat for any extended period, the jets would plug until I started added Seafoam @ 1 oz./gal. - that helped a lot. By all means, if you store the bike for any length of time, stabilize the gas w/ Seafoam & drain the float bowls.
Originally Posted by GoonerYoda
The previous owner recommend some type of fuel cleaner from Yamaha that will help get it running smoother in the long run. Does anyone know what he means by that?
Also, I've heard about seafoam. Educate on that please.
