Weight Loss - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2012, 11:33 PM   #41 (permalink)
Main Motorcycle: 2010 Triumph Scrambler
Yeah, my 'box of parts I've removed' weighs in at 73 pounds, as that's the only real measuring function I have right now. =) My Scrambler weighed in at about 494 dry, is the only real info I have on those regards. I should weigh it over at Evo Motorsports down the road again. Were your triples not alloy from the factory..? Mine are, but they're cast, not CNCed or anything.
I was surprised at the weight of the stock shocks and front fork, though. I saved a bunch on that side.
Perhaps the exhaust, as well, with it's plethora of heatshields accounts for some difference.
What's the weight of your wheels and your new tank? And what's the capacity on the tank? I want a better range, but EFI tanks don't really exist easily found. So I'll probably have to customize it no matter what.
I'm wondering what all on the Thrux might be lighter from the factory! The engine weighs a frigging ton, though. Good lord.
Anyway, I'm just rambling now. =) Thinking about it now, I probably replaced the 73 pounds of goo with 20ish pounds.
Wheels next! Gotta keep the eyes on the prize, the lower unsprung weight.
- Eddie
Originally Posted by NorthernThrux View Post
From my experience, I'd say it is pretty unlikely you removed 70-80 lbs. My Thrux was 471 lbs dry and I got it to 390. Rewired, removed all the emissions crap, airbox etc, just like you. But also lighter wheels, alloy tank, alloy fenders, cut the frame, alloy triple trees, alloy swingarm, motodaget chronoclassic etc. Even stripped off the paint for a few pounds and nickle plated the frame.
Its tough to lose 80 lbs on the bike. And expensive ;-). I'm 170 lbs and 6" 1', so its not like I'm packing extra on my frame. There wasn't anything to gain from dieting for me !
casida is online now   Reply With Quote
Old 11-14-2012, 11:37 PM   #42 (permalink)
You can find 'em here: http://knlcycle.homelinux.com/scrambler.htm
Rear pegs, I recommend grabbing some track ones of the right dimensions and just swapping those, if you wanna keep them.
As far as the footpeg attachment points, you'll either want to keep them as they are if you do anything offroady (The Bonnie ones have had some instances of falling apart) or are hefty. I've not really approached that particular 'issue.'
As far as 'bitubo on front,' my front forks have Bitubo inserts like this:
http://www.bellacorse.com/bcc075.htm
- Eddie
Originally Posted by nametzj View Post
Great looking pegs. Can you remember what they are called, how you knew they would fit?
What is "bitubo on front?"
Any idea how to lighten the massive casting the footpegs attach to?
Rear pegs weigh a ton as well, along with the triangle attached to frame. No idea how to address that; I do need them.
Old 11-14-2012, 11:49 PM   #43 (permalink)
Main Motorcycle: 2013 triumph bonneville
those foot pegs are sexy
any comparison in size next to a stock bonneville peg, i would love to see that
villageidiot327 is offline   Reply With Quote
Old 11-14-2012, 11:58 PM   #44 (permalink)
I could probably arrange that, sure. I'll check in tomorrow-ish with one.
Old 11-15-2012, 03:36 AM   #45 (permalink)
Main Motorcycle: all
Other Motorcycle: dirtbike, vespa 200
Extra Motorcycle: triumph scrambler
Thank you , Eddie those footpegs I will buy!
Has anyone found a better kickstand for the scrambler? Stock leans too far, and weighs a ton as well.
John
nametzj is offline   Reply With Quote
Old 11-15-2012, 03:48 AM   #46 (permalink)
Forgot to say. I put intiminators, about $180, in forks. Much improved in the rocks and far better control in turns on rough roads, both. No weight savings though gotta go after rear shocks next. Stockers not good, specially with that heavy wheel. Shocks probably more important than a lighter wheel for handling/control improvement? Similar cost factor I think.
Old 11-15-2012, 03:55 AM   #47 (permalink)
Main Motorcycle: 2010 Bonneville
Other Motorcycle: wifeys bonnie america
+1 on the heavy box of bits i've stripped off- but the quickest way i found my bonneville to be light was when my wife bought an america......my bonnie felt anorexic after heaving that lump around!!!!!!!
johnnycactus is offline   Reply With Quote
Old 11-15-2012, 07:20 AM   #48 (permalink)
Main Motorcycle: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a CR&S Vun
Originally Posted by villageidiot327 View Post
something i haven't read on this thread is the bolts.
its part of the look of the engine case, i know there are stainless bolt kits available, but they don't do much, if anything for weight.
when i rode road bicycles, every fastener would be titanium, while it is expensive, and not necessarily the strongest bolt material, changing all the engine cover bolts to titanium bolt would save probably close to 10 lbs.
sometimes good deals for Ti hardware can be had on ebay, its just a matter of figuring out what sizes are necessary.
Pro-Bolt have engine bolt kits instainless, titanium and aluminium. If I remember correctly,the ti set will save you about 150 grams, while the alu set will save you about 250 grams (stock set being a tad more than 400 grams). Not a lot, but if it is one of many items changed or dropped then it will contribute.
'04 T100 used to be B&W, now is Aluminium
904, 813, port&polish, Pieman igniter, rebuilt front (valves, springs, etc), Öhlins shocks, tubeless alu rims, JMC alu swingarm, DeCaesar alu triple trees, MeanMachines pipes, Ti nuts and bolts
- Ringer
TB-T100 is online now   Reply With Quote
Old 11-15-2012, 06:49 PM   #49 (permalink)
Main Motorcycle: 2008 Thrux
NorthernThrux's Avatar
Other Motorcycle: 2010 Speed Triple
- Eddie
I'm old and can't remember all the numbers. But I did document it all here http://www.triumphrat.net/twins-tech...build-log.html
Warning it's 27 pages. The triple clamps may be in a different thread, so search for my name and "triple clamps".
Yeah, the engine weighs about 200 lbs. I had to lift it on to the pallet when I shipped it to TPUSA and lift if off and onto the motorcycle stand when it came back. And then I did some head and jug work twice after that. Not much we can do about that lump of steel.
My triples were alloy in top, but cast steel ont he bottom and even the centre tube was very heavy steel. The DeCaeser triple clamp was a lot lighter. Again, numbers are in my build thread.
2008 Thrux. 1087 TPUSA motor. For Sale in the classifieds
NorthernThrux is offline   Reply With Quote
Old 11-15-2012, 06:52 PM   #50 (permalink)
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
That method is only somewhat accurate since there is weight differential to account for on things like exhaust, shocks, etc...
So you need to make sure to subtract the weight of the stuff you put back ON the bike! Best way is to go to a scale large enough to roll the beast on...
beemerrich is online now   Reply With Quote
Weight loss tunertype Speed Triple Forum 4 01-22-2012 08:26 PM
Weight loss on a Thruxton Armen Twins Technical Talk 69 12-14-2011 09:16 AM
Dymag Wheels? Weight Loss? TechmanBD Daytona Deliberations 10 08-18-2009 02:55 AM
1050 Weight Loss 1050kr Speed Triple Forum 5 03-08-2009 02:25 PM
Thruxton Weight Loss robnobrakes Twins Technical Talk 2 02-20-2009 08:41 PM
