On 2005-12-21 13:30, PA-guy wrote:
03 posted: It's definitely getting colder here in Illinois, but the weather warmed up to 35 degrees yesterday so I decided to go for a ride. I pulled the choke, turned the key and let the carbs "warm" for a few before I tried to start it. Well, to cut a long story short, I ended up draining the battery (full charge) before I could get the bike to start. What is the
Question: who was it on this list that wanted the new Bonnevilles to come with a kick starter like they did back in the "good" old days? :???:
the kick starter was never the problem, bad starting technique or badly maintained bike wont start with either kick starter, electric starter or bump starting it down a cliff face
take the trouble to learn what your bike wants, and give it to it. and all will be well.
03cruiser, you have done well by trying to find outthe reason for the failure to perform rather than bad mouthing incalcitrant machinery.. generally when using the choke, do not give it any throttle.. ( maybe just enough to lift it off the stops..) all bikes are a bit different, jus try different things ( vary only one thing at a time ) Once you have the hang of it it wont trouble you again...
keep acheck on your mpg, as this will give first warning of something needing adjustment.
