Scrambler firing order a 270 degree? - Triumph Forum: Triumph Rat Motorcycle Forums
Sponsored by: National Powersports Distributors
post #1 of 27 (permalink) Old 12-14-2005, 02:28 AM
EBcreep
I was just looking at the specs on the new Scrambler model. As a friend is putting a down payment on one.
Turns out it has a 270 degree firing order like the cruisers. Why would they do this? Is there a reason you would not want a lighter bike like this to rev like the thruxton? i dont get it... Can anyone shed light on the logic of going with the 270 firing order over the traditional 360 degree? I thought they did this to add tourque for the heavier bikes?
your thoughts?
bill
post #2 of 27 (permalink) Old 12-14-2005, 05:39 AM
I'd have thought that anything with off-road pretentions would have wanted torque rather than revs.
Pete.
Pete.
Do as you will, but harm none.
Pete_Twizz is offline
post #3 of 27 (permalink) Old 12-14-2005, 06:31 AM
I thought the only reason for the 270deg firing order was to give the cruisers a lumpy tickover - as per V-twins.
This, boys, is a motorcycle.
lunus is offline
post #4 of 27 (permalink) Old 12-14-2005, 07:10 AM
Torque and the exhaust note.
<html>
<body>
<p align=centre>
<A href="http://www.bellacorse.com/index.html"
http://www.bellacorse.com/images/bclogo.jpg</A>
</body>
</html>
RaceDweeb is offline
post #5 of 27 (permalink) Old 12-14-2005, 08:16 AM
EBcreep
hmmm.... it also makes less horsepower and torque! 54hp/51fpt compared to the thruxtox's 69hp/53fpt! What a dog, I don't get it? its the same 865cc motor right?
post #6 of 27 (permalink) Old 12-14-2005, 08:21 AM
Main Motorcycle: 2005 Bonneville T-100
Panthermark's Avatar
Other Motorcycle: Better half's Rebel 250
EBcreep,
No, it has the 865cc engine from the Speedy (270)
The Thrux and the 05 and up T-100's have the 865cc (360)
Standard Bonnies have the 790cc (360)
Americas have the 790cc (270)
:edit:
[ This message was edited by: Panthermark on 2005-12-14 13:45 ]
Mark
Panthermark is offline
post #7 of 27 (permalink) Old 12-14-2005, 08:42 AM
EBcreep
Yes, I realize that. I am just trying to understand the logic of using a version of the same motor (only the cams and crank are different) that has less peak horsepower and torque.
As for the "off road vibe" i don't think anyone in their right mind will be driving one of these in the dirt. Also i would argue that torque is not more suited for offroad. Ever ride a 2-stroke dirt bike? I'm sure all dirt bikes would all still be 2-stroke if it wasnt for the emissions concerns and they are all about the revs.
post #8 of 27 (permalink) Old 12-14-2005, 10:01 AM
This is true.......it's about the torque. If you use the Scrambler like it should be used, it needs the power to knock you on your tush in first gear, like a dirt bike.
Thunder_Forever is offline
post #9 of 27 (permalink) Old 12-14-2005, 03:39 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
Mark,
Substitute Speedmaster for America and vice versa in your above post to make it correct. You risk getting a blast from the Speedy guys. :-D
Larry
Larry
RedBird is online now
post #10 of 27 (permalink) Old 12-14-2005, 03:44 PM
"Mark,
Larry"
U R correct
Whoops, didn't mean to offend anyone.
:wink:
Mark
270 degree vertical twin engine means what? TOMKRILL Twins Technical Talk 12 04-18-2007 10:20 PM
Engine firing order BlueBird Twins Technical Talk 22 04-03-2007 06:38 PM
360 degree firing interval Frankie Club Cafe' 2 12-16-2005 09:02 AM
firing order ???????? mhanson Maintenance & Workshop Talk 2 06-13-2004 04:05 PM
Firing Order Hinckley Classic Triples 3 05-16-2004 08:54 PM
