That's a puzzler. The first thing I'd do is to remove the top fork tube cap and look inside to see if the oil is level with the washer between the spacer and spring. If not, add oil. While you're at it (and with the top cap back on) have someone straddle the bike pushing on the handlebars to compress the front end. And get real close to the fork to make sure it's the fork leg that is squeaking. We're I a betting man, I'd say the brake caliper is the likely culpret. I bet is just loose and needs to be tightened. The other thing that could be wrong is a loose fender. They squeak when loose.
Of course, it could be that the fork tube is slightly bent, and if that is the case, it's not covered under warranty. You might want to explain to your dealer that they are reimbursed from the factory for warranty work, so they should loose the charity-work attitude. Also ask them if they have an internet connection in the shop. They do, they have to, to be able to use Triumph's on-line ordering program. Direct them to this thread and as they if being such tightwads is worth the bad PR.
