Old 12-04-2005   #1 (permalink)
dardoonk's Avatar
I don't mind the stock rear signals, but I think they stick out too far. I was thinking about shortening the stalk to bring them in a little closer to the taillight.
I tried to loosen the nut behind the license plate, but I can't turn it. I can only hold it in place because there's no room to rotate the wrench. I'm afraid to twist on the signal itself while securing the nut.
How do I remove the rear turn signals??
I've gotten this far in life by refusing to act more than half my age, and I intend on continuing this way.
My Photos
'05 America- Works' suspension, Freaked, D&D's, 150 mains, 42 pilots, TBS needles, 1 shim
dardoonk is offline   Reply With Quote
Old 12-04-2005   #2 (permalink)
Other Motorcycle: Harley Softail Deluxe
I'm not familiar with the BA taillight assembly, but taillights/turnsignals are a relativly inexpensie upgrade. Might be woth the $$ to avaiod an unsightly cut, glue/rethread...
stinebiz is offline   Reply With Quote
Old 12-05-2005   #3 (permalink)
Favorite Bike: Speedmaster
Binnsy's Avatar
I asked the same question in an earlier post but didn't get any response.
Feeling dejected I abandoned the project, (not in a hurry to do it anyway).
However, in my first attempt to remove the lock nuts I cut a piece out of a cheap ring spanner to get it on the nut. This worked OK but the threads must have locktite or similar on them and I gave up as It felt like something was about to break.
I am good at effing up jobs like this so backed off for the time being. Let me know how you fare and I might be tempted to give it another shot.
Good luck..........Binnsy :-D
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Old 12-05-2005   #4 (permalink)
Favorite Bike: 06 Scrambler
I have used a box wrench on the nut inside the license plate bracket. It is locktited. I cut the stalk off to the desired length in a lathe and then drill and tap the cut off end with a 14mm tap, install a 14mm stud and drill the stud out to allow the wires to pass thru...works great.
larryshep is offline   Reply With Quote
Old 12-05-2005   #5 (permalink)
Favorite Bike: All of them
banjobart's Avatar
I described how I did this last week, search the forum. It is easy if you have a hacksaw, drill press, 11/32" drill and 10mm tap. I bought the tap at the local hardware.
Just grab the turn signal and turn it a bit so you can get a regular open end wrench on it. It will only take a fraction of a turn to loosen it until it can turn by hand. Disconnect and pull all the wires free.
Cut off the turned down threaded stud that goes into the plate mount. Save it.
Cut off 1-2" from the stalk (I cut 2", the maximum). Drill out the cut end about a half inch deep with a 11/32" drill.
Tap the hole and with locktite screw in the stud that you previously cut off and saved.
Thread the wires back through and reassemble with locktite.
This technique works because the turned down stud on the license plate end is twice as long as need be. There is enough length to cut it off then reinsert it into a new threaed hole after shortening the turn signal stalk.
This took me an hour or two. Do not scratch your chrome, cover it with masking tape. This is a simple job for one who is experienced in the shop but would be a challenge for a newbie.
[ This message was edited by: banjobart on 2005-12-05 08:02 ]
2007 ST 1300
2006 Rocket III
2005 Speedmaster
2004 VTX 1800C
2003 VTX 1800C
banjobart is offline   Reply With Quote
Rear signal ideas drock003 Twins Technical Talk 11 04-29-2007 09:24 PM
Front turn signal stalk holes on headlight brackets Motoleo Twins Technical Talk 6 02-26-2007 03:33 PM
Shortening the turn signal posts johnsime Twins Technical Talk 3 10-05-2006 11:28 AM
Rear Turn Signal Mod HooliganRandy Triumph SuperSports 13 07-03-2006 02:59 PM
Shortening the rear fender? Club Cafe 8 02-11-2005 09:40 PM
