Old 12-04-2005   #1 (permalink)
Other Motorcycle: BMW Rockster 1150R 2003
Extra Motorcycle: Panhead 63 Being rebuilt
Hi. When washing steed this afternoon, I got to the headlamp. The whole lot moved to the right (headlamp and both brackets) but not to the left.. There is something stopping movement to the left.. also I have water/condensation inside the lamp.. Is it normal/or faulty.. Maybe it thinks it's a car with moving headlamps/steering setup!!!
Any light which iluminate my problem will be gratefully received.. RR :hammer: :hammer: :???:
Ronnierockster is offline   Reply With Quote
Old 12-04-2005   #2 (permalink)
The T-100 and Std bonnie headlight assys are designed to move from side-to-side a little. They shouldn't be loose enough to move while you are riding--tighten the acorn bolts on each side if they are loose. The headlight assy is also not water tight. The headlight shell can and will rust inside. I had moisture get trapped in the wiring sub-harness for the instrument lights corroding the splices and the connector inside the headlight shell. There are many other connectors inside the headlight shell--kinda the crossroads for your bike's electrical wiring. :-D
Larry
Larry
2000 year old man 'moves' ! Tbirdnz Biker Hang-Out 3 01-28-2008 03:55 PM
the foolish moves of an obvious newbie metasac Twins Technical Talk 22 05-03-2007 04:18 PM
Back wheel moves in neutral?!?! dkurtz Triumph SuperSports 4 01-06-2007 02:16 PM
Mirror moves at high speed Baltobonneville Twins Technical Talk 8 12-23-2006 01:14 PM
