Randy,
I would suggest running the bike for a few minutes, shut it down and after the oil has had a chance to drain into the crank, check the sight window again. With 3 1/4 qts of fresh oil in it, running it is no risk. If after checking the sight glass again it is a bit lower than before, add some more oil, but between the marks is fine - make sure the bike is on level ground when you check it. And using 15W50 is fine. I use Mobil 1 synthetic 15W15 purchased from Walmart and it is just fine for the Bonnie.
Good luck,
Tom
