Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Old 12-02-2005   #1 (permalink)
I just opened up the bag with the new 17 from Triumph for my bike and they are alot different than the after market ones i have seen they have a chain guide on both sides made of a composite material than i think will last a lot longer darn good thinking says me ..... so if you are looking to change up...... spend the extra for the OEM part when i ordered it i said to my dealer ,,,..what do you think and he said go with the oem part the aftermarket are all right but they dont have the wear guide and now i know what he meant :-D
you dont have to go fast when you look this good going slow
jeffrey1 is offline   Reply With Quote
Old 12-02-2005   #2 (permalink)
It is not a wear guide, its purpose is to dampen the noise of the chain on the sprocket.
Cornelis is offline   Reply With Quote
Old 12-02-2005   #3 (permalink)
I think those are glued on rubber dampers for noise control.They don`t touch the chain or effect sprocket position on the shaft. :???: I looked at Brent`s site and the sprockets for a Bonnie and the Speedy look the same. Is that the case? If it is,there are I`ll bet,half a dozen guys here who would have given you a stock,damped 17t. :evil:
[ This message was edited by: rodburner on 2005-12-02 14:44 ]
Old 12-03-2005   #4 (permalink)
Favorite Bike: All of them
banjobart's Avatar
I'll take one of those 17 tooth sprockets, I will even pay.
2007 ST 1300
2006 Rocket III
2005 Speedmaster
2004 VTX 1800C
2003 VTX 1800C
banjobart is offline   Reply With Quote
Old 12-03-2005   #5 (permalink)
Verify that the Bonneville 17t will fit a Speedy and you can have mine.
Old 12-03-2005   #6 (permalink)
bsmith222's Avatar
The sprockets are interchangeable on all the twins.
-brent
bsmith222 is offline   Reply With Quote
Old 12-03-2005   #7 (permalink)
banjobart's Avatar
Rod Burner,
Thanks very much. Someone has already offered to send me one. If it does not arrive, I will get back to you,
Bart
2007 ST 1300
2006 Rocket III
2005 Speedmaster
2004 VTX 1800C
2003 VTX 1800C
Old 12-03-2005   #8 (permalink)
Cool. I don`t know how much Triumph charges,but I`ll guess its m ore than the 20 I paid for my 19t. If you need help with the install,just ask. Steve
Old 12-03-2005   #9 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Gosh Steve,
Sure wish you had a 16 tooth lying around--I need to go the other direction--too fast with the 17 tooth. :-D
Larry
Larry
RedBird is online now   Reply With Quote
Old 12-04-2005   #10 (permalink)
Too fast?? Hows about I knock one of them there 17 teeth off with my Oral B and send the sprocket your way ? :-D
front sprocket Ski_rat Club Cafe 5 08-27-2007 12:15 AM
front sprocket shadowfever Modifications & Workshop Talk 11 02-07-2007 03:04 PM
Looking for a front sprocket tommyturbo2 Twins Technical Talk 3 11-23-2006 01:50 PM
FRONT BRAKE ISSUE: heads-up to topic in S3 Forum bluesjeans Sprint Forum 3 09-12-2006 07:01 AM
front sprocket tri99sprint Tiger Chat 9 05-11-2005 12:33 PM
