The summer '04 Torque mag had an article and pics of Matt Capri's (South Bay Triumph) Big-Bore Bonnie Blaster. It sure looks like he used the Thruxton headers on that bike. You would probably want to use Thruxton silencers as well--a lot less mounting problems.
I am not sure if the header mounting brackets are the same for the Thrux and Std bonnies; however, if I ever get my hands on a set of Thrux headers, I will make em fit. I just don't like the looks of reverse cone silencers, so I would have to do some work to get the toga style silencer to fit.
Larry
Larry
