Help! T100 wouldn't start - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-26-2005, 10:04 PM   #1 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
I will be purchasing a T100 within the next 3-4 months. Came within a gnats a** of buying one today, a really nice '03 in Goodwood Green/Gold. It wouldn't start! The battery was strong, the tank was more than half full, the petcock was in the 'run' position, and the starter motor cranked the 790cc motor over quickly. However, the motor never fired. Not once. The bike had been ridden within the past few weeks.
Air temperature was probably 38-42 degrees F, well above freezing.
A good friend and Bonneville rider stated that his bike must be cranked forever before it starts in cold weather, and suggested rejetting might cure the problem.
I have a different take on the issue. I believe a box-stock bike with electronic ignition and a good set of Keihin carbs should start in cold weather. It should start with stock jets as the bike comes from the factory. It might take some doing to keep it turning over, but it should start without nearly running the battery into the ground. The bike in question has less than 1000 miles on the odometer.
Point of interest: My W650 Kawasaki uses Keihin carbs that appear to be similar models to those used on the T100. It starts in the coldest weather almost as soon as the starter button is touched.
Has anyone experienced similar starting (non-starting) problems with any of the Bonneville twins? If this is standard 'behavior' for the Bonnevilles in cold weather, I would find this unacceptable, especially since I ride and camp out in some remote areas.
Thanks for any information you can provide.
Bob (ohiorider)
Old 11-27-2005, 12:58 AM   #2 (permalink)
Favourite Bike: 04 Bonnie black
In warm weather,my mostly stock Bonnie starts at the slightest touch of the button. When its cold it may take 5 or 6 touches,but never does it need extended button play. 10 or 15 seconds tops.
Old 11-27-2005, 01:19 AM   #3 (permalink)
Favourite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
The Bonnies are cold natured. Below 50 degrees, both mine and my wife's balk if they have not been ridden for a few days. It will usually take two or three tries to get them started. My sequence is this: I turn of the fuel, pull the enricher (choke) out, put the key and turn it, then hit the starter button - without touching the throttle. Once she fires, I'll give a little throttle. Neither bike has ever failed to start even after sitting for three weeks.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 11-27-2005, 07:59 AM   #4 (permalink)
The temp doesn't appear to be that low to affect the starting of the bike. I have a 2k5 SM and mine starts right away (pure stock) in the low to mid-30's with no issues. I do have to pull the choke out and give it a wee bit of throttle while starting but it usually fires right up.
schwartzkm is offline   Reply With Quote
Old 11-27-2005, 08:18 AM   #5 (permalink)
My old 2001 Bonnie was bad at starting if I used full choke and my new 05 t100 is similar. The best method was to pull the choke out full then back in about 3mm hit the start button dont touch the throttle. Never had any problems since. The T100 started first time yesterday even after 2 weeks sitting in the garage waiting for the frost/ice to go it was about 2C at the time.
markt955 is offline   Reply With Quote
Old 11-27-2005, 09:38 AM   #6 (permalink)
You didn't mention anything about the choke. I assume you did set it. If so, what position did you set it to?
Hal
Daisy, Daisy, give me your answer do.
Hal9000 is offline   Reply With Quote
Old 11-27-2005, 02:35 PM   #7 (permalink)
Favourite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 89XS650,71CT90,82XL80
I use the choke but don't touch the throttle until it first fire's then I give it the smallest amount of twist until it turns all the way over and the let go feathering it with the choke to gain low rpm's. It's never failed to start but it took me 8 month's to figure it out. :brk:
Bryan is offline   Reply With Quote
Old 11-27-2005, 04:40 PM   #8 (permalink)
Same here... Dealer told me to do it this way. starts every time..quickly.
Hal
Old 11-27-2005, 10:25 PM   #9 (permalink)
Favourite Bike: 2006 Triumph Scrambler
DrPat's Avatar
Other Motorcycle: 2009 Triumph Thunderbird
Extra Motorcycle: 2001 Triumph Bonneville
that's odd behaviour for a Bonnie. here's a thought: sometimes this unleaded petrol (you get this in the States?) goes "off" for some reason when it's been sitting in a tank, and not much in there, for a few weeks or longer. It'll run a motor, but not actually fire it up, must lose its igniting quality or smething. Some fresh fuel added cures it. Had this happen in Australia, dunno if it'd help in US or maybe you guys have some better quality fuel, being producers and nearer the source etc. just a thought - cheers DrP.
Dr Pat
DrPat is offline   Reply With Quote
Old 11-28-2005, 11:01 AM   #10 (permalink)
Favourite Bike: 2003 Triumph T100
Sheepdog's Avatar
I had a great deal of trouble with my '03 T100 after prolonged (a week or longer) idleness during the cold weather months. With the stock pipes and airbox, I shimmed up my needles by two #4 washers each. This helped, but I still had prolonged episodes where the engine would run a few seconds and then die. This was with the "don't touch the throttle"/full choke approach. However, I began pulling the choke out and holding the throttle at half...spinning the starter a few revolutions and then releasing the throttle. As soon as the twistgrip closed the engine would fire and hold idle (well, most of the time). I realize that this is contrary to recommendations I've read here, but I've fried starters before on cold-blooded bikes and don't wish to relive that sort of repair bill!
Cold Start problems - New T100 Sossaman Twins Technical Talk 57 12-13-2007 04:37 PM
Love my T100...wish it had a kick start kenhadie Twins Technical Talk 22 09-30-2007 11:59 PM
T100 Won't start mn9130s Twins Technical Talk 18 05-20-2007 10:11 PM
T100 vs T100 Anniversary Edition b_dubbin Twins Technical Talk 9 05-09-2007 05:04 PM
T100 jetting & differences between T100 & Thruxton engines. Nourton Twins Talk 4 05-17-2006 05:48 AM
