'12 Thruxton - Remove Tach or Speedo? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 04-02-2012, 08:07 AM   #1 (permalink)
Main Motorcycle: '12 Thruxton
jstrain's Avatar
Other Motorcycle: '07 Speed Triple
Thinking of cleaning up the dash area with one of Benjie's headlight buckets. I thought I remembered reading that the efi bikes can't run with the speedo disconnected.
Is that correct? Assuming that's the case, am I safe to remove the tach and just put the speedo in the headlight bucket? Will she run without the tach connected?
-Jeremy
jstrain is offline   Reply With Quote
Old 04-02-2012, 03:33 PM   #2 (permalink)
El Moderatore
Main Motorcycle: 2007 Bonneville LeMans
Calliway's Avatar
Other Motorcycle: 1972 CB350
Extra Motorcycle: 1977 GS400
That is correct. In the end you want know mileage and speed so I would keep the speedo.
Calliway is offline   Reply With Quote
Old 04-02-2012, 03:51 PM   #3 (permalink)
Main Motorcycle: 84 Low Rider
I don't see how removing the tach would cause any problems. It is just reading voltage not sending a return to the ecu.
07 Thruxton
SouthofHeaven is online now   Reply With Quote
Old 04-02-2012, 04:20 PM   #4 (permalink)
Main Motorcycle: Bonneville
My 2012 standard Bonneville came with the speedo only. I bought a tach and when I installed it the plug that goes to the tacho was only plugged into the idiot lights. You shouldn't have any problems removing the tacho and just letting the plug dangle or whatever, just know that that plug is also what powers the idiot lights.
MrSandman313 is offline   Reply With Quote
Old 04-02-2012, 10:31 PM   #5 (permalink)
Main Motorcycle: just one? no fair
Danbuc's Avatar
Other Motorcycle: Ducati 748
Extra Motorcycle: Ducati 853R :P
Get a motogadget chronoclassic so you can have your cake and eat it too
"It's not leaking oil, it's just sweating from all the horsepower!"
Mods:Arrow 2-1, BC FEK, BC indicators, BC Quick release cover screws, BC AIRK, CRG mirrors, LSL Rearsets, black 'chazzos', custom 'brushed finish' headlight, NH Damper.
Danbuc is offline   Reply With Quote
Old 04-03-2012, 08:56 AM   #6 (permalink)
jstrain's Avatar
Thanks guys! Looks like I'm spending more money on this bike
-Jeremy
Old 04-03-2012, 11:23 AM   #7 (permalink)
Either do speedo only (most of us know when to shift...you can hear and feel the motor).
Or you could always get a smaller tach and speedo like this:
Cheers
Shane
jad418 is offline   Reply With Quote
Old 04-03-2012, 10:41 PM   #8 (permalink)
Main Motorcycle: 1969 Bonneville
Other Motorcycle: 2005 Thruxton
noob question: is it legal to remove the speedo if the bike came with it? Also: loving the retro looking speedo above.
Fuzzybananas is offline   Reply With Quote
Old 04-03-2012, 11:39 PM   #9 (permalink)
Legend
Forchetto's Avatar
Is that correct?
Yes. If your bike has the CAN-BUS wiring system, (later ones have that), tampering with the instruments can be fraught with difficulties and heartache... One or two members have tried to mod that area and have given up...
There are dire warning in the EFI service manual about it, leave the speedo in place.
Forchetto is online now   Reply With Quote
Old 04-04-2012, 12:07 AM   #10 (permalink)
STW
Main Motorcycle: 2010 Bonneville T100
STW's Avatar
Other Motorcycle: Royal Enfield iron barrel
Interesting because my 2010 EFI T100 with front wheel speedo has had the speedo go out twice--something in broke in speedo gear at the hub. So I've ridden a lot of miles with tach only. Bike ran fine.
Was my speedo supposed to be sending info to the ECU and how could it do that if it was getting no reading? Does this only apply to the 2011 and later Bonnies with tranny speedos?
STW is offline   Reply With Quote
2012 Thruxton Speedo/Tach Backlight jbronso The Welcome Center 1 09-15-2011 01:55 AM
Seeking chrome covers for tach/speedo set - Thruxton Scrambler900 Twins Technical Talk 6 08-06-2010 09:44 PM
chrome buckets for thruxton tach & speedo Thruxton Brothers Club Cafe' 2 10-09-2007 07:42 AM
Will Thruxton Speedo and Tach work on a Speedmaster? Sprocketti Twins Talk 0 08-08-2005 12:43 PM
