Originally Posted by Cyclops116
So adding a tooth gives it more top end and less low end?
You need to understand what changing gear ratios does.
+1 on the counter let you run at less rpm's at highway speed.
It makes 1st gear taller when taking off.
So maybe less acceleration due to higher gearing, but not really.
You just work your gearbox differently (maybe rev out each gear more to pull through and then have more relaxed rpm's once up to speed).
+1 lets 1st accelerate into traffic easier as you don't have to shift to 2nd so soon. Not necessarily quicker.
Going over mountain passes, 5th may not pull. But 4th will rev out to 95+ mph if you need.
If
maxacceleration lol is your thing don't gear up.
If you ride 400 miles a day you might want to gear up, for less highway rpm's.
It will take slightly longer to rev through each gear as you have effectively raised the overall gear ratio. Thus your bike can feel weaker as you get caught at low rpm's in a particular gear.
From my experience a higher top speed can be achieved with the stock counter because you can pull 5th gear better.
Fuel mileage did not improve either as I had to open the throttle more to try to accelerate equally (to stock).
I have gone back to stock couintershaft sprocket for overall tighter gearbox and better overall performance (IMO!).
It all depends on how you ride.
Sorry for the long wind... Understanding your gearing is good!
