Oz, I would hate to think that your chain has stretched that far so soon, so it must be that the chain was simply too long to start with. You have a couple of choices. Assuming that the chain was in fact too long, you could purchase a new one the correct length, or better yet, remove one or possibly two links. If you were considering gearing it up higher, by adding a new countershaft sprocket one tooth larger, you will move the axle forward enough to regain usable adjustment space. If the chain did stretch and there was no damage done to either sprocket ( mis-shaped or bent teeth ) , then you can still get by with removing one or more links. If you damaged the sprockets, you need to replace them and the chain. Putting a new chain on damaged sprockets will wipe out a new chain fast. Conversly, a bad chain will do in good sprockets, but not as quick. Good luck. Dan
