BikeBandit
Old 10-26-2005   #1 (permalink)
I was wondering why Triumph uses cheap stick-on weights instead of the type that attach to the spokes? I noticed this on a couple pf Thruxtons I was looking at in the showroom!!! :???: Will these weights fall off over time?
TC88 is offline   Reply With Quote
Old 10-26-2005   #2 (permalink)
Still on after 6 months and 5600 miles.
2005 T100
Old 10-26-2005   #3 (permalink)
Favorite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2003 Triumph Bonneville T
Extra Motorcycle: 2003 Triumph Bonneville (
One year and two months and 9200 miles - they are still on.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 10-26-2005   #4 (permalink)
Stick on weights have been around so long that they are not considered new. Pretty common on mag wheels. My car has had them for over 10 years with no problems.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 10-26-2005   #5 (permalink)
You're trying to balance the tires imbalance. The closer you can get weights to the tire, the better your balance job is going to be. I would consider the spoke weights to be inferior to the stick on wheel weights because they are further from the tire if for no other reason. I replaced my spoke weights in the 70's with stick on weights because the spoke weights worked loose and caused me problems.
Some stick on weights look better than others--some look like lead and others have a chrome appearance.
Larry
Larry
Old 10-27-2005   #6 (permalink)
1 year, 2 months, 12,500 miles and not a problem.
Thunder_Forever is offline   Reply With Quote
adhesive for brake weights Jerkyboy Twins Technical Talk 1 05-30-2007 08:29 PM
Bar weights BudGT Triumph SuperSports 4 02-09-2007 02:23 PM
Weights ? russ_fae_fyvie Tiger Chat 0 07-08-2005 05:59 AM
slip-on weights DDTT Triumph SuperSports 5 01-26-2005 08:56 PM
Scrungy Weights Modifications & Workshop Talk 10 01-16-2003 11:25 AM
