Jack questions ????? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-24-2005, 04:45 PM   #1 (permalink)
I just tryed my new jack from Sears and have a few questions are you removing the seat first to fasten the straps or just where are you running the straps over the bike
you dont have to go fast when you look this good going slow
jeffrey1 is offline   Reply With Quote
Old 10-24-2005, 06:25 PM   #2 (permalink)
I think I have that same jack! I got mine from SEARS, too. It's wonderful. Sometimes I remove the seat when jacking it up and sometimes not. Depends on if I'm washing it or working on it.
Either way, I place the straps right behind the gas tank over the bike and wrap them around and around. I have a hard time getting a snug fit because it seems like the straps are just too long. Sometimes my strap setups can get "creative." :-D
wnt2rd is offline   Reply With Quote
Old 10-24-2005, 06:41 PM   #3 (permalink)
I have the same jack.
I run the belt under the oil cooler send/return and though the triangle shaped motor mount. I run the rear belt through the triangle shaped rear footrest mount.
EL84 is offline   Reply With Quote
Old 10-24-2005, 11:07 PM   #4 (permalink)
Favourite Bike: Rocket Roadster
Binnsy's Avatar
Other Motorcycle: T/bird gone
Extra Motorcycle: Speedy gone
I run the straps on my jack over the front foot pegs and back down to the other side of the jack. Seems very stable, I gave it a shake the first time I tried it, dumb idea 'cos if it hadn't held the bike would have fallen on the concrete!
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Old 10-24-2005, 11:42 PM   #5 (permalink)
Binnsy,
Top idea, I'll give that a go. I have been taking off the seat and tying down over the frame.
Darcy :chug: :chug:
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 10-25-2005, 04:23 PM   #6 (permalink)
Binnsy's Avatar
Darcy,
I like it over the footpegs 'cos it gives you cleas=r access to the motor, no straps in the way.
You can get good tension on the straps if you jack it up 95% of the way, then tie it down, then jack up that last 5%. The straps pull real tight!
Motorcycle jack retrobiker Classic, Vintage & Veteran 4 11-05-2007 08:02 AM
I'm a Jack*ss johnnyjs1 Hinckley Classic Triples 12 08-01-2007 07:42 PM
Using Jack Yelwoh The Rocket Science Forum 3 05-24-2007 05:57 AM
Daytona 675 Questions & Inline 3 Questions TeddaGreek Daytona675 Forum 11 12-28-2006 12:18 AM
My next 2 questions. Header pipes and New Jack??? Soccermasta Twins Technical Talk 1 10-15-2006 01:46 PM
