Finally getting around to yanking the air injection;read thru the instructions,seems rather straight forward...dug out my wrenchs...I can fit the wrench onto the injector next to the spark plug,but it won't turn due to the shoulder on the wrench...back to the instructions..Says you may need to grind the wrench down to allow for the tight space.Does anyone know of an alternate method/wrench which will work without modification? thin wall socket?I just don't like grinding down wrenchs;it burns the temper out of them,they deflect and strip the bolt points...ruined wrench and even harder removal..I'd rather buy something that WILL work.What's the best way to pull those injectors?
Get it on,get it up,keep the beat
and RIDE WITH ZEKE
BIR #132
TonUp Club San Diego
