Threadlock, anti-seize or nothing on carb bolts? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-05-2005, 01:39 PM   #1 (permalink)
Going to put the allen bolts in the carb bowls today--should I leave 'em naked or slap some goop on?
"In the end, it's all a gag" -Charlie Chaplin
Liontari is offline   Reply With Quote
Old 10-05-2005, 01:45 PM   #2 (permalink)
I've just screwed 'em in; never any problem. Nice and snug does the trick. The steel replacement screws are actually stronger than the cast metal of the carbs, so no gorilla torque. Definitely no loc-tite.
Ruthwell is offline   Reply With Quote
Old 10-05-2005, 01:45 PM   #3 (permalink)
Personally i wouldn't bother. For one thing the carbs are soft metal and the screws won't loosen up like they would in steel. Second, as i recall you're using the stock screws, and loc-tite'ing them in would make for one heck of a time next time you want to remove them. I would order the allens. They not only make it easier but they make it easier to tighte them well without stripping them because you can get a lot better leverage and feel for how much you're tightening with an allen wrench.
Old 10-05-2005, 02:02 PM   #4 (permalink)
Bmotorcycle2003
Be very careful using Allen bolts in this application, especially on an Aluminum casting. It is so easy to strip the carburetor side. Maybe use a small lock washer and again do not over tighten.
Old 10-05-2005, 02:28 PM   #5 (permalink)
I agree with bmotorcycle2003--use a small stainless steel lockwasher on each bolt and no loktite.
2005 T100
Old 10-05-2005, 02:34 PM   #6 (permalink)
OK, thanks--I got the kit from newbonneville--comes with lock washers.
Old 10-05-2005, 06:05 PM   #7 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
I used the lock washers on all except the two holding the idle adjust bracket--screws from NB were not long enough there with the lock washers, IMHO.
Larry
Larry
Old 10-05-2005, 07:00 PM   #8 (permalink)
VR6
I'd slap a little anti-seize. The different metals in contact with one another sets up a galvanic cell, there will eventually be some corrosion form between the two. This will lock the screws in place. The split washer will keep them in place, the anti-seize will keep them from locking up.
VR6 :-D
VR6 is offline   Reply With Quote
Old 10-05-2005, 08:56 PM   #9 (permalink)
Favourite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
VR6 :-D
I second that.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 10-06-2005, 01:18 PM   #10 (permalink)
The alternative to anti-seize is to do what daz and I do--fiddle with the carbs so much that the new bolts never have a chance to seize.
2005 T100
Anti-Heroes Old Scratcher Biker Hang-Out 73 06-11-2008 05:38 PM
Why did it seize? KitNYC T3 Sport / Touring Forum 9 10-23-2007 11:11 PM
anti-seize CCR Maintenance & Workshop Talk 7 07-17-2007 10:51 PM
The new anti-wave Silverado57 Twins Talk 18 07-08-2007 01:17 PM
anti-freeze ORCA Speed Triple Forum 7 03-26-2007 03:06 PM
