zig,
loosen the the back axle and screw the bolts on the adjusters inwards. If you do them both the same amount of turns you won't have to worry about alignment. I pulled my chain off the back sprocket then put it all around the front. Then on as best I could on the back then turned the wheel to pull the chain on.
Make sure the chain is adjusted correctly not too tight about 1 1/2" to 2" on the sidestand seems right, but check when you are sitting on it. It wouldn't be a bad idea to put a bit of lube on the new sprocket as well.
Cheers
Darcy :chug:
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
