But cranking the idle screw to get 1500 rpm is not the same as pulling the throttle.
I would imagine the carbs should be checked for balance at several points in the engine's total range. In Zimmerman's book, he suggests they should remain balanced all the way to full throttle, but not to bother going past half as this should be sufficient.
"In the end, it's all a gag" -Charlie Chaplin
