Which way do the baffles fit in the NH Togas? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-03-2005, 02:43 PM   #1 (permalink)
This may sound dopey but...which way do the baffles fit in? Solid collar facing forward or toward the rear opening?
"In the end, it's all a gag" -Charlie Chaplin
Liontari is offline   Reply With Quote
Old 10-03-2005, 02:47 PM   #2 (permalink)
The solid portion goes to the back. Just drill a small hole thru the baffle (mark the baffle thru the hole in the rear of the muffler first).
Mine came with two screws to secure the baffles with.
larryshep is offline   Reply With Quote
Old 10-03-2005, 06:57 PM   #3 (permalink)
I used 4mm tapered, round head screws 6mm long with a nut on the back. I was trying to get a screw that was as inconspicuous as possible. As Larry said, solid collar to the rear.
Bill
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics), 130 main jets with stock ( NAGB ) needles.
BillT100 is offline   Reply With Quote
Old 10-04-2005, 12:50 AM   #4 (permalink)
Thanks guys...I tried the baffles and took them out after 30 minutes of riding. Sounds better without 'em.
why Togas?? jerryb Twins Technical Talk 21 01-25-2008 01:46 PM
NH Togas gdawg55 Twins Technical Talk 14 07-10-2007 05:12 PM
Anyone using alternative baffles in NH togas? steviek Twins Technical Talk 15 11-01-2006 12:14 PM
J.C. Whitney baffles in Norman Hyde "Togas" BillT100 Twins Talk 6 11-26-2005 02:15 AM
baffles seumas Maintenance & Workshop Talk 3 08-14-2004 09:28 PM
