loose pipe or dastardly sabotage! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-03-2005, 02:42 PM   #1 (permalink)
Can anyone tell me whether the T100 is meant to have a thin open ended black pipe underneath the engine (that left a small fluid deposit under my bike after I left it parked all day) or has some reprobate kindly cut it for me? Ahhh...the perils of living in the capital
adamh is offline   Reply With Quote
Old 10-03-2005, 02:50 PM   #2 (permalink)
If this is a rubber hose about half an inch in external diameter, near your sidestand, it is the overflow tube from the gas tank. One way to tell is to sniff it--it should smell like gas (petrol to you). If the tank is filled and then is left in the sun, the gas expands and the excess drains out the tube, thus your deposit. If you remove the gas cap and look in the filler area, you will see a hole--that is the overflow hole. Try filling your tank just a tad less. And welcome to the forum. I like your choice in Bonnies :wink: :wink:
2005 T100
Old 10-03-2005, 03:18 PM   #3 (permalink)
Badrufus - thanks! I love this forum and my new bike...really weird how you don't know what you need till you happen upon it...
Old 10-03-2005, 03:40 PM   #4 (permalink)
Just wait till you overfill your tank.....when gas is going everywhere you'll really start to worry. :-D
Thunder_Forever is offline   Reply With Quote
Did I loose something?? STRider Speed Triple Forum 8 04-23-2007 03:00 PM
Connection of header pipe to exsust pipe Berkgeorge Twins Talk 5 04-06-2006 05:30 AM
Sabotage ST-ern Sprint Forum 8 10-05-2005 11:40 PM
Loose calipers? KenT140D Hinckley Classic Triples 1 08-02-2004 05:32 PM
