Do you re-balance carbs after every jet change? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.com Classifieds!Ontario TourismMotorcycle.com
Old 10-02-2005, 08:36 PM   #1 (permalink)
Everyone here seems to change their jets more often than their underwear. I'm assuming one has to check carb sync after each change?
Si o no?
"In the end, it's all a gag" -Charlie Chaplin
Liontari is offline   Reply With Quote
Old 10-02-2005, 09:34 PM   #2 (permalink)
I've been doing that because it's changed every time i changed anything. Not a lot tho, but enough to make it sound and feel a little bit smoother. It's a 2 min job tho so no big thang.
Old 10-02-2005, 09:40 PM   #3 (permalink)
I figured it was a good idea to know what's going on...just ordered me a TwinMax.
Everytime I'm faced with something new to do on the bike, I say to myself, "oh man, I can't do that!" then I do it anyway and find it was easier than I thought it would be.
Old 10-02-2005, 09:49 PM   #4 (permalink)
This is one of those times for sure.
Old 10-02-2005, 10:38 PM   #5 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
I don't balance my carbs after jet changes. I believe it takes more than changing jets to get them out of sync. I have changed main jets two or three times in one day when I was experimenting trying to get to a too rich condition to select the proper size. Since I have the tool (Carbtune II), I try to use it every 6 months or so--I have found very little adjustment is needed and I probably didn't need to balance them the last time I did the balance.
Larry
Larry
Old 10-02-2005, 10:52 PM   #6 (permalink)
I just do it because as i've seen it CAN happen, tho you're right Larry in that it's not much or all all. But since i've seen it change a couple times at least, not doing it will always have me wondering. just peace of mind.
Carb jet Change on Legend skeeter1949 Hinckley Classic Triples 4 05-19-2007 11:03 PM
Carbs won't balance Colonel_Dorkus Twins Technical Talk 3 09-10-2006 10:45 PM
Where's the adjustment screw to balance the carbs? DJ Twins Talk 9 04-05-2006 11:51 PM
Jet kit for Keihin carbs USA cable1 Hinckley Classic Triples 4 03-05-2006 02:30 PM
Pilot Jet for TBS Carbs - Help Please spakins Hinckley Classic Triples 3 07-27-2005 02:28 PM
