I wanted to add a fork brace to finish off the front end but the ones I've seen require you to remove the stock guards which means I have to drop the forks. I'm not a lazy guy but just want to avoid having to drop the forks again after i just had intimidators installed... I know poor planning.
Are there any out there that just bolt up behind the stock guards?
You just wrap a screw driver in cloth or a drift and tap them off. Then you cut them at a angle. The reason you want an angle is so you can make them tighter or looser when you glue them back together for a tight fit if you want to reuse them. I too couldn't be arsed takeing the front end off. However what a massive difference the fork brace made and for only £50.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
