Old 09-27-2005   #1 (permalink)
I'm considering either the new Scrambler, or converting an older Bonnie with more ground clearance etc, and was wondering if anyone has ever weighed the standard Bonnie wheels (less tyres)?
I've been given weights by a wheel builders in the UK for some replacement alloy rims, and was wondering how much difference they would make to the unsprung weight against the standard chromed steel rims.
Any drop from the 205kg would probably be helpful :-D but I'm not trying to reach the level of my NX650.
Cheers
Ben
Ben
samwise is offline   Reply With Quote
Old 09-27-2005   #2 (permalink)
Sam -
The rear hub assembly is so stinkin heavy, that losing a few grams on the wheel will probably get lost in translation. Just get something strong, if your really gonna ride it "off-road"
My .02, Cyn-
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 09-27-2005   #3 (permalink)
On 2005-09-27 09:12, CYNCRZR wrote:
Sam -
Actually, dropping a "few grams" on the rims can have a much larger effect than dropping weight at the hub. That's because of
Angular Momentum
Think about starting to swing a weight on the end of a rope over your head. A lighter weight is easier to get moving and easier to stop. Also, easier to change directions too.
A good set of lightweight "superbike" rims will cost racers $5000 or more.
"A skittish motor-bike with a touch of blood in it is better than all the riding animals on Earth." --T.E. Lawrence
http://oldsport.home.comcast.net/photos/oldsport.gif</IMG>
oldsport is offline   Reply With Quote
t140 bonnie rear wheel jpweddle Classic, Vintage & Veteran 1 02-12-2008 10:57 PM
Stock wheel weight sagaris Daytona Deliberations 0 06-15-2007 02:51 PM
Bonnie Weight BlueBird Twins Talk 13 04-06-2007 09:23 PM
WARNING Bonnie wheel Spokes can cause punctures!!!!! fattymatty Twins Technical Talk 28 11-20-2006 08:25 PM
Will new shocks make my bonnie handle more weight rays323929 Twins Talk 11 05-09-2006 08:28 AM
