BikeBandit
Old 09-20-2005   #1 (permalink)
ChrisT100
Hi,
I am planning to replace the standard horn on my Bonnie T100 which I find is not loud enough to make myself heard with a louder one. I checked out NewBonneville.com.
Any recommendations as to which one to get? Since I am not very mechanically talented it should be easy to replace.
Thanks for advice and suggestions!!
Chris
Old 09-20-2005   #2 (permalink)
It is easy to install but be careful about how it is placed. The NB horn has a plastic bell shape on the end which if placed directly down, will hit the fender when the forks compress on large bumps. I ended up facing the horn to the side and eventually will probably trim the plastic bell on the end. Also, the horn will fill with water if you do not cover it when washing so put a bag over it. I think it is louder but I don't count on anybody hearing it. Gives me a little piece of mind if nothing else.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 09-20-2005   #3 (permalink)
Legion
I just fitted a Fiamm HK9 RoadThunder Horn (used be called the K100) - from here RIDERSAFE
It is 134db, black front - cast back. Straight bolt on to a Speedy, One bolt, two connectors - five minutes work - and VERY loud. It's bigger than the standard (about 4" dia). But a great horn if it fits the T100.
[ This message was edited by: Legion on 2005-09-20 22:44 ]
Old 09-21-2005   #4 (permalink)
I recently fitted the NB 125 dB horn under my T100 gas tank. I believe I used the space that was formerly occupied by AI hardware (I had the dealer remove the AI hardware before I picked up the motorcycle so I'm not exactly sure what it looked like). I used the aft most nut-plate under the tank and cut down the bracket that comes with the aftermarket horn. I also shaved off a little of the horn at the outlet (this was not absolutely necessary) to help with the fit. Once I figured out it would fit, the job was very easy. I didn't even have to disconnect the tank gas lines, etc. I just loosened the two tank mounting bolts under the seat, slid it back, lifted it up about 6 - 8" and slipped a big roll of masking tape between the tank and upper frame. That gave me enough room to work under the tank. The horn is LOUD and has a cool European sound (I even ordered another one for my pickup since its horn is dead). One has to really be looking for it to notice it. The bottom is about a half inch below the tank but buried up under there such that it is not noticeable. - dh
CedarCreek is offline   Reply With Quote
Old 09-21-2005   #5 (permalink)
I installed the Fiamm K-100 RoadThunder horn from Ridesafer.com on my '03 T-100 about a year ago. I don't recall any mounting problems. Been through lots of rain and no problems.
Larry
Larry
Old 09-25-2005   #6 (permalink)
ChrisT100
Thanks Guys for Replying!
Chris
Horn replacement T3 Sport / Touring Forum 9 06-07-2007 01:54 PM
Better replacement horn? poffypoffa Twins Technical Talk 17 12-16-2006 10:34 PM
horn replacement mag10 Twins Technical Talk 15 10-10-2006 06:16 AM
Horn replacement DrRocket The Rocket Science Forum 11 09-25-2005 05:42 AM
best horn replacement? motothrux Club Cafe 2 03-09-2005 06:38 PM
