AdvanstarMotorcycleShowsMotorcycle.comBikeBanditTrident-Exhausts.com
Old 09-18-2005   #1 (permalink)
Hi Guys
Just bought myself an 04 Bonneville T100 in black/white.
Bit of a different ride from my previous Suzuki Bandit 600, but this bike is so much fun. Went for a test ride and was totally hooked - it's just everything biking should be!
I've had one problem in the first week of owning it - the dreaded intermittent fault - sometimes I push the starter button and there's a faint click, headlight dims and nothing happens - turn the ignition off and back on and it fires up fine.
Anyone else had a similar problem??
Steveky4 is offline   Reply With Quote
Old 09-18-2005   #2 (permalink)
Welcome,Yet another Steve,check for loose or corroded battery terminals first.Very common here. :-D
Old 09-18-2005   #3 (permalink)
Welcome Steve, Those Back & White T100's are beautiful!
Bonnevilles are just FUN FUN. This forum is The Best! God luck with starting problem-Rodburners advice sounded good. Be Safe :hammer:
Billie I
50yrDream is offline   Reply With Quote
Old 09-23-2005   #4 (permalink)
Problems been getting worse - just been back to dealer who replaced starter relay under warranty. Great service.
Steve
Old 09-24-2005   #5 (permalink)
Favorite Bike: Triumph Bonneville
Other Motorcycle: Ducati 916
Extra Motorcycle: Ducati Pantah Special
Hi Steve. Hopefully it was the relay giving you grief and you're sorted now. If not, however, I'd suggest tracking down the earth connections to the frame and cleaning and greasing them with vaseline.. Worked wonders for my Trophy when it behaved as you've described.
cal6n is offline   Reply With Quote
Old 09-24-2005   #6 (permalink)
Hopefully that was the issue. I had a very similar issue with my Thruxton when it was brand new. Turned out the battery was cracked and had to be replaced. The failure was also intermittent which made it a real pain to figure out.
Go Red Sox!
2005 Thruxton
2007 R1200RT
ThruxtonMI is offline   Reply With Quote
Old 09-25-2005   #7 (permalink)
Other Motorcycle: 66 Bonnie Chop
I had a similar problem last year, completely resolved by a new relay, $12 US fix.
Al
ssjones is offline   Reply With Quote
02 S3 Starting Problem losangeles_S4 Modifications & Workshop Talk 21 07-10-2007 08:39 AM
A Starting Problem Sienna Trophy 6 01-23-2007 05:56 PM
Starting Problem- HELP jeffkimble Twins Technical Talk 10 07-25-2006 02:12 PM
Problem Starting Andrew Trophy 7 02-25-2006 11:08 PM
05 S3 Problem starting up Lom Speed Triple Forum 2 07-04-2005 07:45 PM
