04-08-2011, 05:30 PM
Bonneville Headlight Replacement
Was told by Brent of Newbonneville.com that the perfect headlight replacement for the Bonneville is the Sylvania H6024 sealed beam halogen unit.
I bought one but have yet to install it as I was able to clean the fogging off of the reflector and the inside of the lens of my original unit using a soft cloth sprayed with Windex poked through the bulb opening.
I'm going to try both the original unit and the Sylvania to see which has the best performance.
The only problem that I can see with the Sylvania bulb is that the parking light function is lost.
2003 Lucifer Orange Triumph Bonneville T-100, completely stock except for chromed fenders.
2007 Anniversary Red Ducati GT-1000
Photo: The GT1000 at Utah's Bonneville Salt Flats
04-08-2011, 05:32 PM
SuperStock Main Motorcycle: mine
And you use the parking light a lot do you ??
04-08-2011, 05:48 PM
SuperStock Main Motorcycle: '07 T100
Posts: 207 Other Motorcycle: Also like Ducati S2R 1000 Extra Motorcycle: Would like Street Triple
Wider beam
I find the Sylv bulb has a wider beam that covers the road from ditch to ditch.
A proud SWOMP Rat
'07 B&W T100 AI removed, Lay flat bracket, bars, PS 440 shocks, TORs, etc.etc.etc.$$$$...
04-08-2011, 09:11 PM
Have you noticed what low milage, totally original 100th anniversary model Triumph T100 Bonnevilles have been selling for recently? The point is that this admittedly minor and probably less than useful original feature is lost when the stock headlight is replaced.
04-08-2011, 09:25 PM
SuperBike Main Motorcycle: '07 Black
I'm considering the same mod so please keep us informed. Swap on the new one and take a night ride out to Esperanza. That stretch of I 10's beautiful at night...
"Cognito Ergo Wrenchum"
04-09-2011, 09:12 AM
World SuperBike Main Motorcycle: 2004 Thruxton
Posts: 1,920 Other Motorcycle: 1954 BMW R25/3 Extra Motorcycle: 1971 CB350
Sounds like you need to shelve whatever take offs you have in a box for reinstallation down the road. This is clearly an improvement you can make that is totally reversible...you shouldn't let something like giving up a function that is not used (e.g. parking light) in order to vastly improve a function that you do use.
--Rich
04-09-2011, 12:31 PM
SOTP Vintage Series Main Motorcycle: 2005 Bonneville Blue 790
Posts: 7,144 Other Motorcycle: 1973 CB450, long gone
The "parking light" is useless. I think it's in there to comply with a European safety requirement, just as the side reflectors are there to comply with US requirements.
I unplugged the parking light and stuffed the connector in the headlight shell when I replaced the headlight with a Hella. I saved the parking light and its connector in case I ever want to use the connector to power an accessory, not likely. In any case, I can easily put it back to original, not that I can imagine a reason to do so.
Let us know what you think of the Sylvania. Not everyone likes it.
Marty
04-09-2011, 06:07 PM
Site Supporter Supersport 600 Main Motorcycle: 2010 T-100
I tried several different bulbs and found that the real culprit was the cheap plastic stock reflector. Once I installed a Cibie reflector the Sylvania was a good match.
04-10-2011, 08:16 PM
Team Owner Main Motorcycle: '08 Moto Guzzi 1200 Sport
Posts: 5,508 Other Motorcycle: 2012 Guzzi Griso 8v SE Extra Motorcycle: My 1991 BMW R100GS
I'm sure you are correct re the reflector. My T100 came with an H4 bulb, and the headlight was really bad. On the other hand, my W650 also came with an H4 bulb, and the headlight was excellent. I now run a 6024 on the T100. Much better than the stock setup. Do keep in mind that the 6024 is an automobile headlight, and the lens isn't designed to provide more light to the right side of the road (USA) as are lights with lenses specifically designed for motorcycles.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
04-10-2011, 09:30 PM
Sylvania 6024XV
I replaced the reflector & bulb with the Sylvania 6024XV sealed beam. I find it sheds more light on the road when I ride with friends that have stock. Yes you loose the parking light, but in Canada it is not required. Small price to pay to get better night vision.
From the site:
"Sylvania XtraVision 65-Watt High Performance Halogen Headlight delivers three times more foreground illumination which is designed to create up to 20% more strong illumination and increasing down road visibility with no added glare. It adds 850 hour of a higher wattage light source which is twice the standard sealed beam. This sealed beam project more uniform beam pattern thereby helps to evident better at night which enhances driving safety. This XtraVision headlight been designed for maximum durability and performance."
Hope this helps
FF
A proud SWOMP Rat
