Bonneville Headlight Replacement - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-15-2012, 09:34 PM   #31 (permalink)
Main Motorcycle: 2011 America
photon's Avatar
Other Motorcycle: Not Yet
Does my 2011 America really have a parking light?
photon is offline   Reply With Quote
Old 10-15-2012, 09:58 PM   #32 (permalink)
Main Motorcycle: Scrambler
Olhogrider's Avatar
Other Motorcycle: Sold
Extra Motorcycle: Gone
Can't you just look at it and see? If it has two bulbs in the reflector or it lights up real dim when you use the parking light function, then yes it has one.
Damned Dirty Biker!
Olhogrider is offline   Reply With Quote
Old 11-16-2012, 06:47 PM   #33 (permalink)
Main Motorcycle: 2011 Bonneville T100
TWinOKC's Avatar
Other Motorcycle: 2010 Royal Enfield C5
Has anybody fitted a Sylvania H6024 in a late model bonnie?
I got the Sylvania H2064 at Wally World and attempted to fit it today. It wasn't wanting to go and as it was getting dark and cold, I gave up for the day.
TWinOKC is offline   Reply With Quote
Old 11-20-2012, 06:35 PM   #34 (permalink)
Main Motorcycle: 11 Thruxton
HarlanBarr's Avatar
Other Motorcycle: 72 Kawasaki G4TR
TWinOKC , did you get it to fit ? I had trouble on my 11 Thruxton as well. Same as you gave up because of the cold and lack of light. Couldn't get the retainer ring back on.
HarlanBarr is offline   Reply With Quote
Old 11-21-2012, 06:44 AM   #35 (permalink)
Main Motorcycle: 2001 Bonneville
Irishguy's Avatar
Other Motorcycle: 1974 Honda CB360
I put one in Mrs. Irish's Bonneville, but it's a 2002. It went in like a charm. Maybe the later buckets are different?
Irishguy is offline   Reply With Quote
Old 11-21-2012, 06:47 AM   #36 (permalink)
Irishguy's Avatar
Originally Posted by BonnieBlack View Post
Pull the bulb out, maybe cover the socket up with electrical tape and tuck it in the bucket, no worries. You might use those leads for power one day if you install an after market tach or something.
The bulb has to leads that come off the socket and they go to a plug. I just pulled the whole thing out and left the other end of the plug in the bucket. I think I am going to use that plug to rig up a USB charger.
Old 11-21-2012, 11:37 AM   #37 (permalink)
TWinOKC's Avatar
Same problem as you, couldn't get the retainer to go back on.
The headlight has 3 tabs on the back that make it too thick to get the retainer back onto the outer ring assy. Haven't mucked with it since, maybe after the holiday I will give it another look.
Any assistance appreciated.
Terry
Old 11-21-2012, 12:40 PM   #38 (permalink)
Main Motorcycle: 2009 Triumph Bonneville
Cruzin1a's Avatar
I was going to purchase the Hella also and wanted to know if anyone has that in an EFI Bonny. Curious if the fit is going to be trouble.
Cruzin1a is offline   Reply With Quote
Old 11-21-2012, 01:10 PM   #39 (permalink)
HarlanBarr's Avatar
If I remember correctly , the fitting problem affected the Hella also on later models of the Bonny and the Thrux. That was the reason I tried the H6024 instead of shelling out the extra money for the Hella.
Old 11-23-2012, 11:25 AM   #40 (permalink)
Cruzin1a's Avatar
That's a bummer. The Hella seemed like a nice solution. I'll consider the sylvania but I liked the fact you could change the bulb in the Hella.
headlight replacement com5984 Speed Triple Forum 15 04-12-2011 05:53 AM
Bonneville T100 headlight replacement BG Bonnie Twins Technical Talk 3 11-10-2010 02:16 PM
Headlight replacement FelixLeiter Speed Triple Forum 19 04-26-2009 12:03 AM
Headlight replacement s4 bunjinbantam Triumph SuperSports 5 09-20-2005 09:49 AM
