John,
I think he's talking about the 3rd scheduled service which is at 12,000 miles--not the 36,000 mile service.
Thunder,
I would recommend getting a copy of the items for this maintenance--it's a big one in my opinion. They are supposed to do a lot of checks and replace (renew) a lot of items. It's not just valve check/adjust and oil/filter change.
New air filter, balance carbs, adjust idle using EGA, lube the steering head bearings, and replace fuel hose are among the items listed along with "checking" many other items. Cost should be significant on this one. You will probably have to leave it overnight. The engine should be cool for the valve check/adjustment; and if they do all that's listed, it will take hours. My dealer's mechanic says he requires them to be left overnight for this maintenance.
Larry
Larry
