Baffle Drilling Question - going deeper - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports
Old 09-14-2005, 02:38 PM   #1 (permalink)
So I drilled out the first baffles and removed the tubes that you can see from outside the pipes. That was easy. Now I'm drilling through the internal baffle plates. Are you still supposed to remove more tubes? Cause I can't seem to get that second one out. The hard part is that it's off center so i can only drill around 1/2 to 2/3 of it.
Or are you just supposed to drill a bunch of big holes in the internal plates? :???:
-dennis
2009 Bonneville
d2mini is offline   Reply With Quote
Old 09-14-2005, 06:16 PM   #2 (permalink)
Just drill several holes up in to the muffler. No need (and no way I know of) to remove the tubes inside the muffler.
Bill
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline   Reply With Quote
Old 09-14-2005, 08:23 PM   #3 (permalink)
Dennis,
Just drill through the remaining baffles(plates) with a 1/2", 5/8" or 3/4" drill bit welded to a 1/2" or 3/8" steel rod. It's easy to get off center and harder to compensate with a larger drill bit. Going with a 1/2" drill bit is a little easier. I seem to remember about 5 or 6 internal baffles. If you use anything but a welded drill bit on a rod and lose part of it in the muffler it's almost impossible to get out.
Bill S.
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics), 130 main jets with stock ( NAGB ) needles.
BillT100 is offline   Reply With Quote
Old 09-14-2005, 09:30 PM   #4 (permalink)
As said drill 3 holes thru bafle plates w/ welded extender if you lose the bit in your mufler It has found a permanent home there If it starts to rattle Itll drive ya nuts I believe minus the rear baffle & plate attached there are 3 more to go thru Measure the bit ext to make sure you dont go too far & thru the pipoe itself A litle tape on the bit ext will do the trick Drill till you get the sound where you want it I think 4-3 & 1 did the trick for me Mattewr of choice?
CAPT D
Old 09-15-2005, 12:11 AM   #5 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Gosh Guys,
I lost my bit 5 or 6 times in my mufflers and got it back each time--of course I was not drilling them while still on the bike. One time it came loose while stuck in the most forward baffle--I had to use a curved rod from the inlet end .to push it out of that baffle. :-D Guess you guys have never been around the oil patch and heard guys talking about "fishing" out tools lost in the hole. It can be done! Don't scear these guys so much. :-D
Larry
Larry
Old 09-15-2005, 12:17 AM   #6 (permalink)
Thanks for clearing this up, guys!
So i was drilling away.... and I melted my 1/2" Drill bit! :wow:
I'm not kidding. Its one of those flat bits with the really pointy end. That big point and the chiseled edge of the base of the point is all black and blue and twisted/melted. Dem's some strong baffles! :evil:
-dennis
2009 Bonneville
Old 09-15-2005, 12:23 AM   #7 (permalink)
mrunix
Umm, you mean a Wood bit?!?!? :???:
Old 09-15-2005, 12:33 AM   #8 (permalink)
it said "for wood and metal". But ya, one of those.
-dennis
2009 Bonneville
Old 09-15-2005, 08:41 AM   #9 (permalink)
DJ
Are you rejetting after doing this?
DJ is offline   Reply With Quote
Old 09-15-2005, 10:25 AM   #10 (permalink)
Dunno... that was my next question. But right now I have to go find a bit that is definitely made specifically for metal. Metal only. :razz:
When i had removed the first baffles, I didn't rejet. Just turned the pilot screws out 3 1/4 turns.
So what do you guys thing I should do as far as jetting goes?
-dennis
2009 Bonneville
Baffle removal question Motolink Twins Talk 11 09-01-2006 11:06 PM
slide drilling question sweatmachine Twins Talk 21 08-23-2006 06:55 AM
Baffle removal question ( any idea if this might work?) PCRider Twins Talk 15 01-08-2006 08:07 PM
T'Bird Baffle Drilling ibrown Hinckley Classic Triples 8 07-18-2005 06:51 PM
Question about drilling stock peashooters carlivar Hinckley Classic Triples 30 07-17-2005 06:31 PM
