How to clean a drive chain? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Honda PowersportsNew BonnevilleOntario Tourism
Old 09-14-2005, 06:48 AM   #1 (permalink)
I'm having difficulty in cleaning my drive chain -- the road grit is not coming out completely. I've used degreaser cleaner and brake cleaner. Normally, one or both of those clean the chain well, then I re-lube the chain. This time, I hear the grit in the chain links -- not good. Any ideas?
Thanks! - Andy
Andrew Lazarewicz
alaz is offline   Reply With Quote
Old 09-14-2005, 08:58 AM   #2 (permalink)
Kerosene and a small fairly stiff brush, after a ride when the chain is still warm.
larryshep is offline   Reply With Quote
Old 09-14-2005, 10:10 AM   #3 (permalink)
Favourite Bike: 02 Bonneville
Other Motorcycle: 1972 Honda CL450 Scrambler
I've found that WD-40 and other types of penetrant oils in spray cans work real well also. Just apply a generous helping of chain lube or wax afterwards. Kerosene seems to be the most used method for good results.
Shorty
Different Strokes, for different folks.
2002 Red & Silver Bonneville
http://i22.photobucket.com/albums/b3...Bonneville.jpg
http://i22.photobucket.com/albums/b3...4/e0d93963.jpg
Shorty is offline   Reply With Quote
Old 09-14-2005, 09:21 PM   #4 (permalink)
Favourite Bike: Can't Pick One
ChuckofTahoe's Avatar
Other Motorcycle: 2005 Bonneville T100
Extra Motorcycle: 2000 Sprint RS
Bring it to the dealer. Maybe keep your hands clean. Saves money on that Boraxo and Gojo stuff :-D
Photos
Web Site and Blog
ChuckofTahoe is offline   Reply With Quote
Old 09-14-2005, 09:56 PM   #5 (permalink)
Diego's Avatar
The problem with penetrating sprays is, that's exactly what you don't want happening to the o-ring or x-ring seals in your chain, because that could let contamination inside the rollers. Any particular type of solvent may or may not attack the rings--but you won't know for sure until it happens. Best to stick with what the manufacturer recommends, which is kerosene.
John
Old 09-14-2005, 11:33 PM   #6 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
I use a tooth brush; however, there are some special brushes made for cleaning chains. I haven't had to clean the chain nearly so much since I quit using Chain Wax. The Bel Ray Super Clean doesn't collect as much dirt and grime in my opinion. :-D I have 9K and have never adjusted the chain--these new o-ring and x-ring chains sure beat the ***** out of the old chains!
Larry
Larry
Old 09-14-2005, 11:37 PM   #7 (permalink)
Oops, didn't know c-r-a-p was a no-no word for this forum. Please don't ban me to the R3 forum. :-D
Larry
Larry
Old 09-15-2005, 12:43 AM   #8 (permalink)
Thank you all! I used a wax-based chain lube, recommended by my dealer, but the wax makes road grit stick to everything. I've had knowledgeable mechanics recommend engine cleaner, then a standard cleaner / degreaser, then lube.
Biggest concern is damaging the chain. I did not know that kerosene was the preferred method until this thread. Much appreciated!
- Andy
Andrew Lazarewicz
Old 09-15-2005, 01:19 AM   #9 (permalink)
Favourite Bike: 04 Bonnie black
Larry
Which one? All the folks who made it worth reading have moved on.Their moderator seems to be singlehandedly keeping that forum alive.I personally think every forum needs a "back room"to escape to after reading your 47th jetting question,and the R3 forum was the special video section behind the beaded curtain.
rodburner is online now   Reply With Quote
Old 09-15-2005, 10:44 AM   #10 (permalink)
Favourite Bike: My '03 America
agogel's Avatar
Just about any decent motorcycle shop and most bicycle shops have a product called a "GRUNGE BRUSH".
These have an adjustable head to fit your particular chain and let you clean 3 sides at once. Put a big piece of cardboard down on the floor under the rear wheel first and get some kerosene. I usually remove the chain guard first. The "@@!!??" just about melts off.
When done, I put a fan on the rear wheel to help evaporate what I can't wipe off.
Yes.....your hands will get dirty.
Tony G
"If you don't get what you really want, it's your own fault"
agogel is offline   Reply With Quote
What do you clean your chain with? ThruxtonMI Twins Technical Talk 9 03-26-2007 04:46 PM
BEST WAY TO CLEAN A CHAIN BullClark Maintenance & Workshop Talk 17 02-07-2006 01:10 PM
how to clean chain? boostedpirate Speed Triple Forum 15 09-11-2005 07:20 AM
How to clean chain ? Sprint Forum 9 09-20-2004 11:22 PM
Best way to clean chain? Serious_Dave Maintenance & Workshop Talk 14 09-21-2003 04:26 AM
