TPS Gone- What a difference!! - Triumph Forum: Triumph Rat Motorcycle Forums
Closed Thread
Old 09-13-2005, 09:56 PM   #1 (permalink)
DXed the TPS today A lot of posts about the subject
With TPS connected Sometimes ran like a banshee (when glowing hot) Sometimes it was I think I can attitude No real pattern cept temp TPS gone it is YO CAN DO!! all the time !!
Idles better Runs better at all temps Another good concept that didnt quite live up to its expectations?? Erratic performance?? Worth a try Ride On! Capt D
CAPT D
CAPTDON is offline
Old 09-13-2005, 10:35 PM   #2 (permalink)
Simply unplug it? Got a pic of the plug I should look for? Seems pretty reversible and worth a try...
Pack Leader, LINY RATs
'02 Black Bonnie America
Anyone on long island?
bennybmn is offline
Old 09-13-2005, 10:46 PM   #3 (permalink)
I've been told it's the plug just behind the carbs. I haven't DXed mine yet.
bog_rat is offline
Old 09-13-2005, 10:47 PM   #4 (permalink)
Ok I think I know the one, it's the only electrical thing on the carbs I think.
bennybmn is offline
Old 09-13-2005, 11:30 PM   #5 (permalink)
I think the wires that plug into the bottom of the carbs are the carb heaters so don't pull those! Maybe someone could describe the location of the plug better than I can, because I am just going by what I was told, and haven't looked too closely yet. + I seem to keep getting my facts wrong on these forums so don't trust me!!! :-D
bog_rat is offline
Old 09-13-2005, 11:44 PM   #6 (permalink)
Pardon my ignorance, what is a TBS ? and what is its function? I don't feel too comfortable just unplugging things. Jack
BTHUMPER is offline
Old 09-13-2005, 11:45 PM   #7 (permalink)
Sorry, I meant TPS.
BTHUMPER is offline
Old 09-14-2005, 12:00 AM   #8 (permalink)
Favourite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
Throttle Position Sensor
Carl S
Old Soldier
CarlS is offline
Old 09-14-2005, 01:32 AM   #9 (permalink)
This is so tempting to try. But is it wise to remove something that advances the timing, or does it indeed do that? (from what i've read here it does) I would think timing should be advanced only by something that senses RPM's, not throttle position. Because you could be at very low RPM's and twist the throttle all the way and advance the timing when it shouldn't be advanced. can someone explain how this works in detail and where my logic is flawed because i gotta be missing something here. guess i'll get out the manual and see if it describes it...
dazco is offline
Old 09-14-2005, 04:59 PM   #10 (permalink)
Daz do you remember on old cars there were weights in the distributor, and a vacuum thing on the side of it. The weights were centrifugal and flung out at higher RPM. The vacuum device was powered by the induction through the carbs. Both of these would advance the spark as the engine speed increased. The TPI does the same thing (so I am told) but does it electronically as the ignition is now electronic. The amount of advance would be very, very slight as we have better fuels now, and better ignition systems and everything else.
bog_rat is offline
Closed Thread
Tps Sensor Harold The Rocket Science Forum 3 10-15-2007 09:05 PM
TPS & Shimms? webonnielad Twins Technical Talk 2 08-26-2007 03:24 PM
TPS and BC ECU SCCTrim Twins Technical Talk 48 04-30-2007 10:27 PM
TPS? mikeinva Twins Technical Talk 7 04-03-2007 10:29 PM
TPS Sensor Removal ! WA53JHO Twins Talk 21 09-12-2005 08:56 PM
