Rat,
My recommendation is to give Works Performance a call--they are out in your area and they make shocks that are second to none and they make them to fit you (they make them to your specific weight with riding gear). If you are not satisfied with them, they will rebuild them until you are! Price is about the same for similar shocks, but their higher performance shocks can approach $500 or more.
My dealer is an old racer and he will not ride a bonnie unless it has Thrux length shocks on it. He says it makes all the difference in the world in how it handles in curves. Of course he doesn't ride with stock shocks either.
Since you are inseam challenged, I would stay with the stock length or go 1" shorter and look into lowering the front the same amount. With your weight, I believe you will be much happier with shocks from Works.
Larry
Larry
