Old 09-07-2005   #1 (permalink)
dirk
Hi, I am posting this question for a friend. We have a '70 TR6R with a 4 speed tranny. We are trying to replace the 4 speed with a complete tranny from a Bonneville. The questions are: What mods need to be done? What parts are needed? Any mods necessary to shifting mechanism? Are the inboard transmission cover/case different? The 5 speed transmission was installed on the bench and it does not shift.
I appreciate any insight or experience in making this conversion that you guys can give us.
Thanks.
Old 09-07-2005   #2 (permalink)
Dirk,
If you haven't, try posting your questions on the pre-Hinkley classic/vintage/vetern forum--whatever its called--it's the one below this one. On this forum we're usually wrapped up pretty much with the new Bonnevilles.
Larry
Larry
Old 09-07-2005   #3 (permalink)
dirk
will do. thanks Larry.
Daytona 955i speed triple conversion!! Flat6 Daytona Deliberations 4 06-08-2007 09:46 AM
Daytona 955i to speed triple conversion. Flat6 Speed Triple Forum 6 06-01-2007 10:19 PM
5 speed conversion dirk Classic, Vintage & Veteran 3 09-08-2005 10:54 PM
95 Speed Triple handlebar conversion Nic900 Modifications & Workshop Talk 2 06-29-2005 10:02 PM
Six Speed Conversion rwven Speed Triple Forum 1 06-15-2004 06:44 PM
