Old 09-04-2005   #1 (permalink)
while riding the other day I noticed that my stock headlamp brackets although pointing straight were actually slightly angled to the left. I never noticed it before. Has one of my family members dropped my bike while I wasn't around or is this the normal stock set up? everything else appears normal (no dings or scratches of any kind).
"...two roads diverged in a wood and I, I took the one less traveled by and that has made all the difference."
WindyCityTwin is offline   Reply With Quote
Old 09-04-2005   #2 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
Works great if you only turn left. Loosen the headlight bolts and drop the head light out. You should be able to move the headlight "ears" freely. If that doesn't work, check and see if the forks are twisted. Maybe somebody hit it with a car in the garage? :???:
Brooksie is offline   Reply With Quote
Old 09-05-2005   #3 (permalink)
Given that the bolts to the headlamp shell are at the same seperation as the forks on which the brackets are mounted, rotation of the mounts should have no effect on headlamp aim.
Pete.
Pete.
Do as you will, but harm none.
Pete_Twizz is offline   Reply With Quote
Old 09-05-2005   #4 (permalink)
There's NO problem with your bike. The headlamp housing is designed to move from side to side a little. Just push it from one side or the other to straighten it WITHOUT loosening the acorn bolts. If it doesn't remain in that position while riding, tighten the acorn bolts on the headlight some. Yes, it can be moved enough to affect headlight aim! NO, you do not need to loosen the acorn bolts to move the headlight brackets from side to side an inch or so.
Next time you are at the dealers, move all the bonnie headlights from side-to-side, and ask the salesman what is wrong with them--he probably won't have a clue. :-D
Larry
Larry
Old 09-06-2005   #5 (permalink)
Brooksie's Avatar
Cool stuff! Just goes to show ya...you learn something new every day!
Old 09-06-2005   #6 (permalink)
Blame it on the rubbers! Namely, the rubber seals above and below each headlamp bracket.
There is an advantage to the wobbly headlight. Fasten a piece of string to each side which then goes to each handgrip When you are in the mood for doing a searchlight raid you can point it anyway you want. Good for hunting ducks at night!
Triumph are so clever.
:razz:
Archimedes is offline   Reply With Quote
Old 09-06-2005   #7 (permalink)
Interesting. I should check my Bonnie to see if her headlight is straight. I could have pushed it to the side while polishing. Something to check everynow and again.
It's funny what can be bumped while cleaning. I thought I was going crazy when my odometer went from 85 to 205 miles. I knew I had to stop for gas that day anyway, but swore someone played a joke one me while parked at work. More likely I just bumped it while doing my morning pre-ride dusting.
ponycorn is offline   Reply With Quote
Old 09-06-2005   #8 (permalink)
Favorite Bike: '05 T100
I believe the design is intended to isolate the headlamp from vibration at speed, a problem I've noticed with older bikes having rigid mounts. I like that I can easily adjust, even when going down the road at night. However, bumping the headlight can throw it out of adjustment quite easily.
"It was like that when I got here..."
Clifford is offline   Reply With Quote
I would like to have both headlight on? tman11535 Tiger Mods & Bolt-Ons 4 02-19-2007 10:57 AM
Headlight rvendena Twins Technical Talk 12 01-04-2007 08:03 PM
Geometry whiplash23 Speed Triple Forum 8 09-24-2006 09:55 AM
Headlight ? Geoff Twins Talk 12 05-14-2006 04:59 PM
Headlight Looking4ST Sprint Forum 2 03-25-2005 03:12 PM
