AdvanstarMotorcycleShowsBikeBanditMotorcycle.com
BikeBandit
Old 08-16-2005   #1 (permalink)
Is it just me or does anyone else have a problem with the left hand mirror (clutch lever side) constantly moving? No matter how hard I try to tighten it, the thing keeps swinging around. Any ideas anyone?
4plus4morgan is offline   Reply With Quote
Old 08-16-2005   #2 (permalink)
There is a little spring bush between the mirror stalk and the mounting hole. This seems to be there to keep enough tension on the mirror that it stays in place but loose enough that it would pivot on a drop.
(love the 4+4-congratulations on it)
Paul
Paul is offline   Reply With Quote
Old 08-16-2005   #3 (permalink)
Thanks Paul, I will have a look and make sure the spring bush is still there!
Yes the 4/4 is great in this weather, but rarely comes out over in Blighty!
Old 08-16-2005   #4 (permalink)
Favorite Bike: '07 Tiger
Whisperinsmith's Avatar
Other Motorcycle: '06 Sprint, sold along with '05 America and '69 Bonnie
Extra Motorcycle: 200cc cheap dirt bike
i had the same issue this weekend. by accident i discovered if i turned the entire mirror clockwise (on the screw), it tightens down great. then rotate the mirror itself in a circular turn to put the bulk on the high side. (you'll see what i mean when you turn it.) then after step one is tight, and step two has it set right, then you can tweak it little by little.
it was annoying, but now it's set tight. good luck.
Life. Fill 'er up. It's all we got.
http://www.armchaircommando.org/benn...Bash/Home.html
Bennington, VT May 31, June 01 2008
Whisperinsmith is offline   Reply With Quote
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe 13 06-17-2008 09:04 AM
Mirrors Colin955Devon Daytona Deliberations 8 08-22-2007 06:38 PM
mirrors rockenrobert The Rocket Science Forum 1 03-10-2006 08:10 PM
Mirrors (again!) ic Speed Triple Forum 5 10-09-2005 07:02 PM
Can the mirrors Sir_Loin Speed Triple Forum 9 04-14-2005 11:53 PM
