Old 08-10-2005   #1 (permalink)
I just had the bike dyno`d.
It put out 64.1 hp.
The mechanic told me it isn't showing sign of running lean.
He thought it ran great & likes the Thunder pipes.
Told me bike was running fine & did not need to rejett.
Said if I check the spark plugs to look at the electrode for signs of running lean,not the ceramic.
[ This message was edited by: dowop on 2005-08-10 17:08 ]
dowop is offline   Reply With Quote
Old 08-10-2005   #2 (permalink)
So aside from snorkel removal and thunderbike pipes your bike is stock? This is about a 3 HP difference over the stock specs which is hardly what they advertise. (28% power increase advertised) I wonder if the snorkel removal hinders the power gained with the TBP's?
[ This message was edited by: dazco on 2005-08-10 11:49 ]
Old 08-10-2005   #3 (permalink)
You are right.
The bike was not dyno`d with the snorkel in.
But you can feel the increase in midrange acceleration right away after removing it.
I do have AI removed & the air screws out 4 turns.
I also changed the sprockett to a 17 tooth a couple of weeks ago & I really like it.
The bike hit a 128 mph on the dyno.
It would not do that in real world conditions,but the mechanic was impressed.
I never expected a 28% increase.
The guys at the dealer ship liked the sound of the pipes also.
Old 08-10-2005   #4 (permalink)
I believe that the stock HP specs refer to power at the crank, not the rear wheel, as is measured by the dyno....I believe 64 HP is pretty good....
Radiator is offline   Reply With Quote
Old 08-10-2005   #5 (permalink)
'I believe 64 HP is pretty good....'
That's good.
Grandpaul is offline   Reply With Quote
Old 08-10-2005   #6 (permalink)
feliz's Avatar
Yes, 64 hp on our bike is very good!! I think mine did 52 when I had it on the dyno stock.
I have seen some graphs where hp dropped after snorkel removal.
feliz
03 Bonneville T100, 73 Honda CB750, 05 Ural Patrol, 07 BMW F800ST, 58 Matchless 500, 07 Ducati GT1000
feliz is offline   Reply With Quote
Dyno results oil-spitn-rat Hinckley Classic Triples 6 02-10-2008 12:24 PM
dyno results trumpete The Rocket Science Forum 4 11-17-2007 11:16 PM
Dyno Results. Silver Streak Sprint Forum 0 10-03-2007 08:40 AM
Thruxton Airbox Removal K & N Filters & Rejet DYNO RESULTS robnobrakes Club Cafe 26 03-29-2007 12:51 AM
Dyno Results TrackerOldGuy Speed Triple Forum 17 08-18-2006 06:08 PM
