Closed Thread
Old 08-09-2005   #1 (permalink)
Washed my bike today and found a shiney place I don`t recall seeing before. Anybody feel like walking to the garage and taking a peek for me?Down near the oil filler plug,on top of the case are 3 bolts of which 2 remain.Could it be a missing wiring tie-down? Thanks,Steve [they are in an array nearest the fill hole.] :???:
rodburner is online now
Old 08-10-2005   #2 (permalink)
Steve, if I'm looking in the right place, the third hole is for a wiring clip. The wires that run down to the sensor in the engine case go through a plastic loop on mine, the loop has a round part that is supposed to fit that hole. Mine is always out, it doesn't stay plugged in properly. Bad design.
Don't sweat it.
Erik
My Baby
Copper is offline
Old 08-10-2005   #3 (permalink)
two bolts and one non threaded hole black plastic wire holder glued in hole you could use a black zip tie the wires dont move around to much - ron
ronsuesan is offline
Old 08-10-2005   #4 (permalink)
I've used a little clear silicone glue to hold it in place. It still loose now and then
"A skittish motor-bike with a touch of blood in it is better than all the riding animals on Earth." --T.E. Lawrence
http://oldsport.home.comcast.net/photos/oldsport.gif</IMG>
oldsport is offline
Old 08-10-2005   #5 (permalink)
This plastic plug/clip fell out of that hole on my Thruxton, so I simply cabled tied the wires together and plugged the hole with a domed-head black rubber plug.
Furbags is offline
Old 08-10-2005   #6 (permalink)
Don't sweat the petty stuff, and don't pet the sweaty stuff!! :-D
Fighting Terrorism Since 1861.
Christov is offline
Old 08-10-2005   #7 (permalink)
Thanks to all. Will steal some 33 year old technology from my SL175 to make repair.
Old 08-10-2005   #8 (permalink)
Of course, I still think you may have a screw loose........
:-D :-D
My Baby
Copper is offline
Old 06-12-2006   #9 (permalink)
Okay, newbie twin owner here ... and see that I even searched before asking this :wink:
So, is this the extra blind hole, missing bolt boss that we're talking about here. Noticed it while wiping down the new baby and was wondering what the heck is supposed to be here???
No, it's not that old. Yes, they still make them. You did, really? The guy that stopped me ten minutes ago had one too.
RGSeeds is offline
Old 06-12-2006   #10 (permalink)
RG,
Good research; however, there was another, more recent thread (about a month ago if my memory is correct) that would be more "up-to-date" than this nearly year old thread. If my memory is correct, the later thread brought out the fact that Triumph no longer (beginning with the 2006 models--I believe) routes the wires where this hole is used for a wire tie-down...so, the same hole on your '06 is an unused hole. :-D Again, my memory is kinda old like the rest of me, but I believe I remember reading that the wires are routed to the rear of the engine and under on the '06's.
Larry
Larry
RedBird is offline
Closed Thread
Did I loose something?? STRider Speed Triple Forum 8 04-23-2007 02:00 PM
I had a screw loose when I bought my Bonnie T100... dcpyatt Twins Talk 12 05-29-2006 05:05 PM
Bonnie screw loose MotoSayle Twins Talk 8 05-12-2006 01:10 PM
Loose Mirror - What kind of screw head? Berto61 Twins Talk 2 08-23-2005 05:25 PM
I have a screw loose JesusHoffa Modifications & Workshop Talk 6 11-20-2004 04:44 PM
