Old 08-05-2005   #1 (permalink)
sho-me
Hello I.m a newbie to the board and just got back into the triumph scene after many years away from it. I have a question about tach hook-up. I have an 05 america and am trying to hook up an oem tach, Could someone tell me what color wires are connected with the wire that goes from the igniter to the head light bucket
The instuctions talk about pluging the ends into specific places, but these wire connections already have a wire in them. Thanks
Old 08-05-2005   #2 (permalink)
Favorite Bike: 2005 Bonneville Black
Lion's Avatar
Well not sure if the Bonneville wiring is different then the way they wired the America, but I have an 05 Bonnie and it was completely plug and play all the wiring was wired out to a connector located in the headlight, the instructions tell you that if you have VIN # or later that you just plug it in to the receptacle and you are good to go...
Joe
Lion
Joe's 2005 Bonnie Black
Lion is offline   Reply With Quote
Old 08-05-2005   #3 (permalink)
Favorite Bike: My '03 America
agogel's Avatar
Your "05 America should have the connector harness directly under the tank dashboard. Just match up the plugs from the tach to the empty connector under there.
There was a lack of this additional connector on some earlier model Americas....'02 and '03's I think, but you should be good to go.
By the way...where is Fair Grove?
Tony G
"If you don't get what you really want, it's your own fault"
agogel is offline   Reply With Quote
Old 08-05-2005   #4 (permalink)
Favorite Bike: '07 Tiger
Whisperinsmith's Avatar
Other Motorcycle: '06 Sprint, sold along with '05 America and '69 Bonnie
Extra Motorcycle: 200cc cheap dirt bike
I put the tach on recently and have the same bike as you and it's "plug and play". The '05 has the harness already wired with the ends waiting for the new tach. Just take off the three screws for the insturment cover plate and lift her up and you'll see the proper connection. You can't plug it into the wrong place. Just pop out the Triumph logo plug and you're in business to simply put the new tach there. Don't freak out if it doesn't line up, you can twist it later.
By the way, the biggest pain in the whole thing is disconnecting the battery lead. If anyone can tell me how to do this easily without taking off the seat, I'd appreciate it.
Life. Fill 'er up. It's all we got.
http://www.armchaircommando.org/benn...Bash/Home.html
Bennington, VT May 31, June 01 2008
Whisperinsmith is offline   Reply With Quote
Old 08-05-2005   #5 (permalink)
sho-me
Thanks all for the input, just could not get the thing to work. Finally figured out it was a bad tach, another is on it's way.
Bungee hook idea tri650 Speed Triple Forum 1 09-18-2007 12:30 AM
GPS hook up Tooth Trophy 3 07-31-2007 04:50 AM
Tach help? 3rd gear @ 35mph What's the tach read? JMart121 Twins Technical Talk 4 06-25-2006 05:56 PM
Is it called towing hook ? solorider The Rocket Science Forum 1 03-01-2006 09:49 PM
Where to hook a bungee cord? judf Sprint Forum 12 09-01-2005 05:10 PM
