Springfield ArmoryMotorcycle.comBikeBanditSportbikeTrackGearAdvanstarMotorcycleShowsShopTriumph.comMotorcycle.com Classifieds!RacerPartsWholesaleTrident-Exhausts.com
TriumphPerformanceUSA
Old 07-30-2005   #1 (permalink)
LSW
Mikey, Larry
Thanks for the info. My first project will be to get the rest of the AI components off the bike that were left on it. The metal tubes in the head were removed along with the two hoses but everything else is still there.
I plan on ordering a service manual on Monday but will be removing the tank tomorrow so I need a few tips on removing and replacing it safely. I read in an earlier post that you disconnect the fuel line, remove the rear bolts and move the tank back and up to remove it. It seems pretty simple but wanted to be sure.
Thanks
Scott
LSW is offline   Reply With Quote
Old 07-30-2005   #2 (permalink)
LSW
Sorry, I hit the wrong button. This is a reply to Mikey and Redbird in the post down below.
Scott
Old 07-30-2005   #3 (permalink)
you got it. aj
jabrady1234 is offline   Reply With Quote
Old 07-30-2005   #4 (permalink)
Remove the two 6mm bolts from the back of the tank. Use a 8mm wrench (size of the hex head). Disconnect the fuel line on the left and the vent tube on the right. Pull back a couple of inches and then up.
Reverse procedure to reinstall.
[ This message was edited by: RaceDweeb on 2005-07-30 15:33 ]
<html>
<body>
<p align=centre>
<A href="http://www.bellacorse.com/index.html"
http://www.bellacorse.com/images/bclogo.jpg</A>
</body>
</html>
RaceDweeb is offline   Reply With Quote
Old 07-31-2005   #5 (permalink)
LSW
Thanks RaceDweeb.
Just returned from Sears with 300.00 worth of new tools. Tomorrow is Tank day. Got in touch with the great folks at NewBonneville and they hooked me up with the airbox plug and carb vacuum cap I didn't have. Ordered yesterday and it arrived today.
Truxton Gas Tank Same As Bonnie?? azrat Twins Technical Talk 1 01-25-2008 11:57 PM
'06 Scrambler - Size of gas tank dh-ad Modifications & Workshop Talk 4 08-16-2007 07:16 PM
gas tank and seat replaced under warranty ctrhenry Speed Triple Forum 2 04-18-2007 11:25 PM
Gas Tank Size??? ArmyBonnie Twins Talk 2 08-31-2005 11:54 PM
Fastener Size On Bonnie Gas Tank And Seat ? LSW Twins Talk 7 08-01-2005 12:32 AM
