BikeBanditAdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 07-24-2005   #1 (permalink)
For those who have installed the Bonneville grab rail, how simple was the installation? Christov?
Allan
AllanCook is offline   Reply With Quote
Old 07-24-2005   #2 (permalink)
As I recall, it was very easy and straightforward. No worries.
Bill H
bhart1239 is offline   Reply With Quote
Old 07-24-2005   #3 (permalink)
As I recall, I think the rear fender needed to be removed for installation. I personally did NOT do this installation, but had it done by the dealer when I purchased the bike. IF you do decide on the grabrail, I think you will be quite pleased. The quality is top notch!!
Fighting Terrorism Since 1861.
Christov is offline   Reply With Quote
Old 07-24-2005   #4 (permalink)
Favorite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2003 Triumph Bonneville T
Extra Motorcycle: 2003 Triumph Bonneville (
Christov is correct to the best of my memory. I installed the high sissy bar which attaches to the same rails as does the grab rail. The rear fender had to be removed to install this rail. The directions were straight forward and I had no problems. the stock screws that hold the rear fender (mudguard) are pretty poor quality. While I was at it I replaced them with stainless steel screws I bought from Ace Hardware.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 07-25-2005   #5 (permalink)
I'm not particularly mechanical and I did it easily. You'll really like the look, too.
Mike
MikeinLA is offline   Reply With Quote
Old 07-25-2005   #6 (permalink)
I installed the grab rail on my 05 Bonneville a couple of months ago. It was a complete piece of cake (yes the read fender has to come off but it's not a problem). The only problem I had was with getting my Corbin gunfighter & lady seat back on. The grabrail and/or dresser bar (can't remember which) interferred slightly with the sides of the Corbin. The fix was easy. I shimmed the Corbin seat rear bracket with a couple of washers. Problem solved. -dh
CedarCreek is offline   Reply With Quote
Old 07-26-2005   #7 (permalink)
Allan, I have one on mine, it fits perfectly with the NH solo seat and the smuggler as well.
Highly recommended. Easy install.
I had to cut a small piece of the plastic airbox away to get enough clearance for the mounting bolts to pass through. No big deal.
-Mark.
TexasT100 is offline   Reply With Quote
Old 07-26-2005   #8 (permalink)
Maybe I'm missing something here, but I installed Triumph's grab rail on my '03, and all I had to take off was the seat. No need to remove the rear fender.
Bill
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline   Reply With Quote
Old 07-26-2005   #9 (permalink)
Favorite Bike: '05 T100
Hi Allan,
Yeah, you do have to remove the rear fender, the reason being that you have to bolt into some attachment points on the top, inside of the rear shock mounts. It's really easy though, there are only four screws and one electrical connector attached to the rear fender. You can have it off in under five minutes. The rest of the grab rail installation is pretty easy too. When you get your grab rail, you'll find it has instructions included.
Cheers!
"It was like that when I got here..."
Clifford is offline   Reply With Quote
Grab rail help Futuraman Twins Technical Talk 7 09-27-2007 08:43 PM
Grab rail marcosmaniac Sprint Forum 11 09-28-2006 11:44 PM
Grab Rail for 05 S3? Xibalban Speed Triple Forum 6 08-24-2006 10:24 AM
S4 Grab rail BigPappa Triumph SuperSports 6 01-05-2006 09:20 AM
Grab Rail-yes or no? HiVel Speed Triple Forum 1 10-31-2005 01:56 PM
