Old 07-16-2005   #1 (permalink)
I had run across a step by step pictorial that somebody had posted on this site about installing an aftermarket tach on their Bonneville. Can somebody please help me find this posting. Tried using the search engine but without success. Thanks
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 07-17-2005   #2 (permalink)
I bought the tach. Waste of money.
Roadglide is offline   Reply With Quote
Old 07-17-2005   #3 (permalink)
I have to disagree that the tach is a waste of money. I purchased the factory style and installed it on my '02 Bonneville, and it has been flawless since installation. The tachometer after installation "completes" the look of the Bonneville. Without it, the bike kind of looks cheap. The '04 installation should be easier than the '02, since the wiring harness has changed slightly. You will be removing your headlight lens to gain access to your wiring. From what I have heard the newer Bonnevilles don't require a separate wire run to the coil. I don't think you will even have to remove the fuel tank. You will only have to remove the speedometer and the bezel that it is installed into. Remove the lenses for the dash lights, reinstall them into the new bezel. Transfer the speedometer housing into the new bezel. Install the tachometer into the other space in the new bezel. Install the new trip reset knob into the odometer slot. Other than that there's not much more. I am sorry I can't be more specific, but I did mine over 3 years ago, and no longer have the installation instructions to refer to.
Fighting Terrorism Since 1861.
Christov is offline   Reply With Quote
Old 07-17-2005   #4 (permalink)
Favorite Bike: 05 T100
Doesn't it tell you your engine speed then? What else would you expect from a tacho for the money?
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
Old 07-17-2005   #5 (permalink)
Thanks, but the tach I was looking at was a small one that was purchased on E-bay and tucked very nicely next to the speedo casing. Looked like a nice cheap solution. Hopefully the poster will run across this.
Old 07-17-2005   #6 (permalink)
Favorite Bike: '05 T100
I think there are two kinds of people; those who primarily use a speedo, and those who primarily use a tach. I've always used a tach and have to make a point of watching the speedo, otherwise I often find myself going over the speed limit. Those who use primarily use a tach are interested in getting the max performance out of their engine without damaging it. I don't ride my engine excessively hard very often, but when I do I a tach is crucial, you can't tell where your redline is by sound or feel.
"It was like that when I got here..."
Clifford is offline   Reply With Quote
Old 07-17-2005   #7 (permalink)
Since the factory rev limiter kicks in well before engine damage is a concern, a tach on a Bonneville isn't an absolute necessity. On the other had, I've never had a bike without a tach. I like gauges and gadgets. The more infomation I can get about road speed, engine speed, engine temp, oil pressure, charging system health, etc., the happier I am.
Most motorcycle engines can be classified as high performace, at least compared to other vehicles. Any high performance engine with a manual transmission is kind of incomplete without a tachometer IMO.
TrumpetPlayer is offline   Reply With Quote
Old 07-17-2005   #8 (permalink)
Clifford, I agree about the tach v. speedo thing. I've always had a tach, and I find that I use it more and have to discipline myself to check the speedo. But I usually know what gear I'm in and can estimate my speed by just looking at the tach.
TrumpetPlayer, like you said, any high performance engine without a tach is incomplete, and any engine on a New Triumph, or most older ones for that matter, is high performance. You can tell alot by the sound of the engine, but a tach gives you much more precise feedback. If you're just trolling along, a tach isn't that important, but if you're riding more actively, a tach is quite helpful.
2005 T100
Old 07-18-2005   #9 (permalink)
Favorite Bike: 02 Bonneville
Other Motorcycle: 1972 Honda CL450 Scrambler
I had the Triumph Tach installed before I took delivery of the bike. I just felt that the instrument cluster didn't look balanced the way it came from the factory and I didn't like the looks of the aftermarket small tachs which were being offered.
Shorty
Different Strokes, for different folks.
2002 Red & Silver Bonneville
http://i22.photobucket.com/albums/b3...Bonneville.jpg
http://i22.photobucket.com/albums/b3...4/e0d93963.jpg
Shorty is offline   Reply With Quote
Old 07-18-2005   #10 (permalink)
Favorite Bike: '07 Tiger
Whisperinsmith's Avatar
Other Motorcycle: '06 Sprint, sold along with '05 America and '69 Bonnie
Extra Motorcycle: 200cc cheap dirt bike
I bought after market pipes and without the tach I would have had a tough time regulating the mixture. I hope your installation of the tach goes as easy as mine on the America. Well worth the effort from my point of view, but I'd go with the Triumph tach. Not only for looks, but for installation instructions and wiring ease. Good luck.
Life. Fill 'er up. It's all we got.
http://www.armchaircommando.org/benn...Bash/Home.html
Bennington, VT May 31, June 01 2008
Whisperinsmith is offline   Reply With Quote
looking for tachometer tyges Twins Technical Talk 2 07-16-2007 11:56 AM
Tachometer JKDJose Twins Technical Talk 2 04-16-2007 04:26 PM
Tachometer pineygroveshop Tiger Workshop 13 11-01-2006 08:19 AM
Need tachometer stu Twins Technical Talk 7 10-31-2006 02:46 PM
tachometer Blownfuse Classic, Vintage & Veteran 1 08-24-2005 12:39 PM
