BikeBanditMotorcycle.comAdvanstarMotorcycleShowsSpringfield ArmoryRacerPartsWholesaleSportbikeTrackGearTrident-Exhausts.comMotorcycle.com Classifieds!
ShopTriumph.com
Old 07-16-2005   #1 (permalink)
As many of the folks that have installed the NH m-bars have noted, they can result in an increase in handlebar buzz. The buzz will cause the stock mirrors to make the view behind you blurry at speeds above 50 or 60 mph and can also cause your hands to go numb on longer rides - at least all of this was the case for me. In my opinion this is the only negative about the m-bars. Even with this, I've been very please with them after about 1200 miles.
Last weekend I installed the liquid version of barsnake (www.barsnake.com) in my bars. The results were pretty positive. I don't know that the buzz situation is as good as with the stock bars but I think it's pretty close. It's a very noticeable improvement over the m-bars without the barsnake.
For those of you who may not have heard of the barsnake, the standard version apparently is a "snake like" thing that can be slid into the bars to add weight and reduce vibration. I couldn't use the standard version since I have the m-bars with the welded in bar cap adapters (i.e. plugs). So I ordered the liquid version. It is intended for bars with tight bends or internally routed cables, etc. that would make installing the standard bar snake impossible. It comes in two bags that you mix together just before pouring into the bars. It's about the consistency of sticky pancake batter. To get the stuff past the hole in the bar end adapters, I bought the largest syringe that I could find at a farm supply center (60 ml used for animal vaccinations). The cure time is 24hrs.
If you have the m-bars and would like to reduce the buzz, you might want to give this stuff a try. - dh
CedarCreek is offline   Reply With Quote
Old 07-18-2005   #2 (permalink)
Favorite Bike: '05 Triumph T100
bosoxrider's Avatar
Has anyone just rotated the stock bars down with any positive results?
~=Bosoxrider
~=Other album
"That's right. White Lotus. Yam-yam. Shanghai Sally."
bosoxrider is offline   Reply With Quote
Old 07-18-2005   #3 (permalink)
Favorite Bike: '05 T100
Rotating the handlebars down, isn't that an old cafe racer trick?
"It was like that when I got here..."
Clifford is offline   Reply With Quote
Old 07-18-2005   #4 (permalink)
I've rotated my bars down a little and they became (for me) quite a bit more comfortable. I didn't try to flip the bars, but just rotated them back a little - nice feel. I'm going to try some Western bars (from Bellacorse) and see how they are. With these bars I'm going to use a pair of Napoleon bar end mirrors - I think they will quell any little vibration there might be. The Western bars look a little better than the stock bars and are the same width and about the same rise and pullback.
Tom
[ This message was edited by: grebmrof on 2005-07-18 19:10 ]
grebmrof is offline   Reply With Quote
bar end mirror vibration jfenton Twins Technical Talk 8 09-05-2007 07:30 PM
Strange fix for the M bar buzz anglen Twins Technical Talk 3 07-17-2006 07:32 AM
Help stop those M-bar vibes. (More bar end weight) Panthermark Twins Talk 1 05-10-2006 09:16 AM
Anyone Drill out the solid bar insert?--Napoleon Bar End Mirrors KAH24 Club Cafe 4 03-28-2006 05:59 PM
M-Bars: Dampening the Vibration w/o Bar Ends bosoxrider Twins Talk 15 08-15-2005 01:02 PM
