Checking Oil Without A Center Stand - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 03-14-2010, 03:49 PM   #1 (permalink)
Favourite Bike: 2007 Bonneville T100
greatescape's Avatar
OK, here's another dumb newb question. Sorry, but I just want to make sure I'm not missing something really obvious (which happens sometimes).
Is there any good trick for checking the oil if I only have a side stand? Obviously the bike needs to be level to get an accurate reading, and I don't have the money to drop on a center stand or jack right now. Obviously the PO has been checking the oil for the last 4 years (granted, he worked in a motorcycle shop).
So short of asking my girlfriend to sit on the bike for me while I check (which she graciously did for my first oil change), is there a better way to do this? I can barely see the oil window if I straighten up the bike from the handle bars and look down, but I come dangerously close to dropping my bike every time I try this. I guess I could try leaning it up against a wall, but that seems sketchy too.
greatescape is offline   Reply With Quote
Old 03-14-2010, 04:08 PM   #2 (permalink)
Favourite Bike: 2009 Bonneville SE
Forchetto's Avatar
I have two methods: I place a block of wood of the right thickness under the side stand to make the bike almost, but not quite vertical. walk round the oil window side and take a look.
Another one is simply to go down on one knee at the right side and slowly pull the bike towards you. If there's a good light you'll soon see the oil rising in the window.
Old 03-14-2010, 04:43 PM   #3 (permalink)
Favourite Bike: Triumph Street Triple.
Other Motorcycle: Ibis Mountain bike.
Oil Level...
The easy way ....
In the morning before I ride, I simply pull the bike upright off the side stand from the R/H side of the bike.
Balance it perfectly upright for about 10 seconds, then let it go back down onto the side stand.
Crouch down and look at the oil level sight glass. There will be a film of oil on the inside of the glass indicating where the oil was when the bike was upright.
Easy....
S.
2010 Street Triple. Black.
"Just because you're breathing doesn't mean you're alive"
Sp00ky is offline   Reply With Quote
Old 03-14-2010, 07:40 PM   #4 (permalink)
Favourite Bike: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
My wife has a 4" round mirror with a stand. I just place it next to the bike and look down.
Mike
2007 Black / Red T100 AI removed, Hella H4 "E" Class Headlight, Feked Toga style mufflers 118 mains 40 pilot 2 3/4 turns out, Dual Star heated grip kit.
First Bike: 1966 Yamaha YL1 Twin Jet
The older I get, the faster I went.
McBike is offline   Reply With Quote
Old 03-15-2010, 12:00 AM   #5 (permalink)
All good tips. Thanks a lot fellas.
Old 03-15-2010, 10:25 AM   #6 (permalink)
Favourite Bike: '02 Bonneville
Dan in Cibolo's Avatar
As a Newbee, I used the block of wood method. Of course, I had to also use a flashlight. Balancing the bike and looking at the same time may work for some, but was very dangerous for me.
In an older post, some owners swear they could sit on the bike, and lean over to read the oil level. They must have necks that are about two feet long. LOL
Previous owner of a beautiful
'02 Bonneville ... British Racing Green
Sold 28 Aug '09
Previous Motorcycles: R-51 & R-53 BMW; '58 Triumph TR6SR; '70 Honda 750.
Dan in Cibolo is offline   Reply With Quote
Old 03-15-2010, 10:55 AM   #7 (permalink)
Favourite Bike: '09 Mystery Black EFI
teachnsurf's Avatar
When Should One Check Oil: Hot or Cold
So when should one check oil?
When the motor is cold?
or
10 minutes or so after she's been running?
This is my Bonneville. There are many like it, but this one is mine. My Bonneville is my best friend. It is my life. I must master it as I must master my life. My Bonneville, without me, is useless. Without my Bonneville, I am useless.
teachnsurf is offline   Reply With Quote
Old 03-15-2010, 11:19 AM   #8 (permalink)
Favourite Bike: Café Racer
TIE-Pilot23's Avatar
Other Motorcycle: MotoTerminator
Telescopic Inspection Mirror...
"A Stormtrooper has food...he's got food...but a TIE Fighter Pilot got food...he's looting...
...Emperor Palpatine dont care about TIE Pilots!"
TIE-Pilot23 is offline   Reply With Quote
Old 03-15-2010, 11:41 AM   #9 (permalink)
Forchetto's Avatar
or
Either will do.
Old 03-15-2010, 11:53 AM   #10 (permalink)
What do we know about the subject "wet sump" and exhaust smoke?
mgrosso is offline   Reply With Quote
Will it flip-over backwards w/this stand + center stand? TheNomad Sprint Forum 6 05-20-2009 01:23 PM
Chain adjustment-center stand or side stand? andyc740 Trophy 7 04-02-2008 06:41 PM
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 03:53 PM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 07:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
