Anyone have seat bolts laying around? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 03-09-2010, 07:07 PM   #1 (permalink)
Favourite Bike: '05 Triumph Bonneville
Craigore's Avatar
Other Motorcycle: '51 Harley Panhead
Extra Motorcycle: '79 Harley Ironhead
I'd pay for you to ship them to me if you have no need for them anymore.
somehow one vibrated loose and I can't see spending $28 + $8 shipping on the ones offered by the vendors
I have some main jets that I can send if you need them.
Craigore is offline   Reply With Quote
Old 03-09-2010, 07:18 PM   #2 (permalink)
Favourite Bike: 2009 Bonneville SE
Forchetto's Avatar
They're just M6 x 1.0 pitch x 20 mm long stainless steel allen screws. iconBike Bandit has them for $2.48 for a set of two.
Most hardware stores will have something suitable for a few cents. Unless you're talking about those extended types. Scrambdaddy has made some of those very cheaply as described on this post:
http://www.triumphrat.net/twins-talk...ml#post1496535
Old 03-09-2010, 07:39 PM   #3 (permalink)
Craigore's Avatar
Great idea I think I'll try that
Old 03-09-2010, 08:24 PM   #4 (permalink)
I just grabbed a couple allen head bolts/screws out of my drawers of junk,a normal to long allen wrench works fine,they dont stick out like an extended screw but work fine. Theres really nothing to get at under the seat on these bikes anyway.
Flattrack loon is offline   Reply With Quote
Old 03-09-2010, 09:22 PM   #5 (permalink)
Favourite Bike: 2007 Thruxton Bonneville
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
here's a fix that means no more messing around with allen keys.
Heres a very cheap fix.
Buy two ordinary hex head bolts with the same thread as the Triumph ones. Thread them through the lugs on the frame but from behind i.e the other way, so that you end up with two threaded studs protruding from where the seat bolts normally fit. You might have to drop the mudguard and bend the frame tab slightly ( I did) Then get two wing nuts. Put the seat on threading the seat tabs over the studs. Fix the seat on with the wing nuts. Much cheaper than fancy over priced extender bolts. Works just as well as you can now remove the seat easily with your hands.
Here's some pics to explain. Attached Thumbnails
Nickwiz is offline   Reply With Quote
Seat bolts Tri-oomph! Sprint Forum 34 11-28-2007 12:07 AM
Seat Bolts chewy7676 Twins Technical Talk 8 08-01-2006 08:42 AM
Seat bolts (again) Gootch Twins Talk 0 06-12-2006 04:30 PM
Seat Bolts? AllanCook Twins Talk 5 07-08-2005 05:57 PM
Anyone got a Stock Seat laying around Bushwhacker Tiger Chat 7 08-18-2004 10:27 PM
