Give us a little more info: What year T-100? Did you buy it new or used. Any mods to it, if so list them. Where do you live--this gives us an idea of Wx conditions.
I'm not sure "choke assembly adjustment" is going to be of benefit--it's a pretty simple assembly and should be functioning properly.
When my '03 T-100 was stock, it was much more "touchy" on my use of the choke than it is since doing mods to the exhaust and intake with corresponding jetting changes. If I remember correctly, when stock and during the hot summer months, I couldn't put the choke on full to start the engine when cold without problems.
Larry
Larry
