'07 Bonnie losing power..... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-25-2010, 09:27 PM   #1 (permalink)
Favourite Bike: Bonneville
sween's Avatar
Hello All,
I've been having a small problem with my bike the last 2 or 3 rides. I'll be cruising along and all of a sudden it skips like it would if it were running out of fuel; it loses power for a second, and then magically regains it. The last incident was on the freeway going about 70 so I'm pretty concerned. I've check and I have plenty of fuel and my hand hasn't bumped the kill switch. I also cleaned the air filter thinking that may have something to do with it. Has anyone else run into a similar problem? I am pretty green in the wrenching department so any advice will be appreciated.
sween is offline   Reply With Quote
Old 01-25-2010, 09:30 PM   #2 (permalink)
Favourite Bike: 2007 Thruxton Bonneville
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
Ignition pick up coil. Its probably failing. Mine went and my ignition coil failed too. Not sure if one caused the other or if it was just coincidence. Either way check them. Most likely to be that.
Nickwiz is offline   Reply With Quote
Old 01-25-2010, 09:34 PM   #3 (permalink)
Favourite Bike: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
Could be debris in your fuel tank. Take off the tank, drain it, pull out the petcock (take notes/draw pictures on how it comes apart for reasembly) and clean the filters (two of them, one is the main and the other is the reserve), rinse the tank out a couple of times with a bit of clean fuel. Reassemble. I've done both of my bikes and had a fair bit of rust and peeled paint in them. I didn't experience the symptoms you have had but I can see how the debris left in there and build up over time could cause fuel starvation/blockage.
Good luck!
'06 Scrambler: De-AI'ed, De-Snorked, K&N, Dual entry airbox mod, TORS, 135mains, 40pilots, thrux needles, no shims
'07 Bonnie Blk: De-AI'ed, De-Snorked, K&N + NH Peashooters, 118mains, 40 pilots, one shim
'05 Tiger 955i: Pulled airbox plate
cdubya is offline   Reply With Quote
Old 01-26-2010, 08:04 PM   #4 (permalink)
sween's Avatar
thanks cdubya. took your advice and removed the gas tank and ran some clean gas through it last night. i filled it up with a fresh tank and added some fuel system cleaner. it ran without a problem and even seemed to have a little more pep than before. thanks for your post as well nickwiz.
Old 01-27-2010, 09:09 PM   #5 (permalink)
Favourite Bike: '01 Bonneville
cgrossarth's Avatar
Other Motorcycle: '01 Suz Intruder 800
If your problem persists, also check the fuel tank
vent for blockage. Unvented tank will not flow
fuel properly.
cg
Implementors of national policy for the last 400 meters.
2/325 Inf.
cgrossarth is offline   Reply With Quote
Losing Surge/Power on Speedmaster cocoselect Cruisers - America, Speedmaster 9 11-17-2009 11:55 AM
Losing power at or above 4500 rpms. Chilly Trophy 5 03-31-2009 01:11 AM
Losing Power CCSO3932 Twins Technical Talk 5 02-09-2009 09:00 AM
losing power under load brent mason Twins Technical Talk 10 01-17-2009 06:18 PM
hottest day yet this year - Bonnie losing power ivar Twins Technical Talk 15 08-10-2007 08:50 AM
