Here is some more stuff on the Bonneville Performance team from the Sideburn Magazine blog. Sideburn is an awesome flat track/speedway magazine based in the U.K. that covers the past and present of going fast and turning left...
http://sideburnmag.blogspot.com/sear...le+performance
Sideburn Magazine
Bonneville Performance Street Tracker:
Specs:
1200cc Triumph Powered
Engine: 1200 cc 270 degree crank 101 mm bore 74.3 mm stroke
104 rear wheel HP @ 8000 rpm
91 ft. lbs. torque @ 4300 rpm
Frame and swing arm 4130 Chrome molly
Wheel base 55.5 inches - adjustable to 57.5 inches
Steering head angle 24.5 degrees
Front suspension modified (lengthened) Yamaha R6 43 mm 3 way adjustable cartridge forks Billet triple clamps with 1 mm to 7 mm offsets
Rear suspension Penske 3 way adjustable mono-shock
Front wheel Performance Machine
Rear wheel Performance Machine
Front brakes - 2 - Beringer 6 piston Aerotec calipers with Suzuki K4 298 mm rotors
Rear brake - Beringer 2 piston floating Caliper A&A Racing 10.5 inch rotor
Wet weight 351 lbs.
